So I have installed HAOS on a esxi virtual machine. It has been working flawlessly for over a year now, but the time has come to upgrade (Or rather totally replace) that machine. So I have downloaded the ovf and vmdk files from the one, created a VM on the other, powered it up… And a lot of stuff doesn’t work…
The MQTT seems to refuse to accept connections. None of my devices will connect to it (Well, I havent tested every single one, but it seems most won’t) MQTT explorer refuses to connect. Shelly isn’t working. And my Zigbee Home Automation doesn’t want to work either. (Zigbee connects to a sonoff wifi zigbee hub)
So far the only errors I have found can be summed up here:
Couldn’t start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator
11:29:53 PM – (ERROR) Zigbee Home Automation - message first occurred at 11:29:36 PM and shows up 2 times
Couldn’t start application
11:29:53 PM – (ERROR) /usr/local/lib/python3.9/site-packages/zigpy/application.py - message first occurred at 11:29:36 PM and shows up 2 times
I am honestly at a total loss. I don’t even know how to troubleshoot this, as there should be no changes whatsoever. Is there someone that can tell me what is going on, or at least help me troubleshoot this?
