Move HassIO to SSD on Odroid XU4
Hi, I previously run my Home Assistant on Ubuntu 18.04 on Odroid XU4 on SSD, quite simple to move Ubuntu to external SSD, just copy file system to external SSD and change one line in the /media/boot/boot.ini on the SD or eMMC memory.
It will still boot from SD or eMMC but directly switch to SSD on boot.
Now I have moved to run HassIO on the Odroid XU4 but the instructions to move it to external SSD does not work as it is not Ubuntu in the bottom but Alpine,
Is there a way to move HassIO to the external SSD in a simular way?
