Move Lambda to Package
In the Process of Breaking My EspHome Yaml files into Packages to make them more Managable.
Not Sure How to Deal with this Example though,
Existing Code Block.
display:
  - platform: ili9xxx
    model: ILI9341
    cs_pin: 22
    dc_pin: 01 #TXD 0
    reset_pin: 03 #RXD 0
    dimensions:
      height: 240
      width: 320
    transform:
      swap_xy: True    #L/Scape Pins on LHS
      mirror_x: True
      mirror_y: True
#      swap_xy: True    #L/Scape Pins on RHS
#      mirror_x: False
#      mirror_y: False
    invert_colors: false
    color_palette: 8BIT
    color_order: bgr
#    update_interval: 10s # Added While Trying Lvgl
    lambda: |-
      it.fill(Color::BLACK);
      // Get the hostname (derived from the 'name' in esphome: section)
      // You can also get it from the API if needed, but for display purposes,
      // the 'name' is often sufficient.
      std::string hostname = App.get_friendly_name() + ".local";
      // Print the hostname on the display
      it.print(0, 0, id(robo_30), id(blue_1), TextAlign::TOP_LEFT, "Spa Monitor");
      //it.printf(0, 50, id(robo_25), id(grn_1), TextAlign::TOP_LEFT , "Current Temp:    %2.1f", id(spatmp_cur).state);
      it.printf(0, 50, id(robo_25), id(grn_1), TextAlign::TOP_LEFT , "Current Temp:-");
      it.printf(320, 50, id(robo_25), id(grn_1), TextAlign::TOP_RIGHT ," %2.1f", id(spatmp_cur).state);
      //it.printf(0, 75, id(robo_25), id(org_1), TextAlign::TOP_LEFT , "Temp Rise:        %2.1f", id(spatmp_rise).state);
      it.printf(0, 75, id(robo_25), id(org_1), TextAlign::TOP_LEFT , "Temp Rise:");
      it.printf(320, 75, id(robo_25), id(org_1), TextAlign::TOP_RIGHT , "%2.1f", id(spatmp_rise).state);
      //it.printf(0, 100, id(robo_25), id(gry_1), TextAlign::TOP_LEFT , "Temp to Target:   %2.1f", id(spatmp_req).state);
      it.printf(0, 100, id(robo_25), id(gry_1), TextAlign::TOP_LEFT , "Temp to Target:");
      it.printf(320, 100, id(robo_25), id(gry_1), TextAlign::TOP_RIGHT , "%2.1f", id(spatmp_req).state);
      //it.printf(0, 125, id(robo_25), id(blue_1), TextAlign::TOP_LEFT , "Flow Rate:       %2.1f", id(sparet_flo).state);
      it.printf(0, 125, id(robo_25), id(blue_1), TextAlign::TOP_LEFT , "Flow Rate:");
      it.printf(320, 125, id(robo_25), id(blue_1), TextAlign::TOP_RIGHT , "%2.1f", id(sparet_flo).state);
      it.print(0, 160, id(robo_15), id(wht_1), hostname.c_str());
      it.printf(0, 180, id(robo_15),  id(yel_1),TextAlign::TOP_LEFT , "Ap: %s", id(testesp1_ap).state.c_str());
      it.printf(0, 200, id(robo_15), id(blue_2), TextAlign::TOP_LEFT , "Ip: %s", id(testesp1_address).state.c_str());
      it.printf(0, 220, id(robo_15), id(blue_1), TextAlign::TOP_LEFT , "Up: %s", id(testesp1_uptime_f).state.c_str());
      // For example, displaying time
      it.strftime(320, 220, id(robo_15), id(blue_1), TextAlign::TOP_RIGHT , "%H:%M:%S %d-%m-%Y ", id(snpt_time).now());
      // Plain Text Example
      //it.print(160, 220, id(robo_30), id(red_1), TextAlign::TOP_LEFT, "Hello World!");
      //it.printf(0, 30, id(robo_30), id(blue_1), TextAlign::TOP_LEFT , "%.1f", id(testesp1_uptime_s).state);
I’ve Tried these two blocks as Package Files, but the Editor Reports them as in Error.
disp_conf.yaml
display:
  - platform: ili9xxx
    model: ILI9341
    cs_pin: 22
    dc_pin: 01 #TXD 0
    dimensions:
      height: 240
      width: 320
    transform:
      mirror_x: True
      mirror_y: True
#      mirror_x: False
#      mirror_y: False
    color_palette: 8BIT
    color_order: bgr
And
disp_lambda.yaml
    lambda: |-
Then Use:-
esphome:
  friendly_name: TestEsp-1
packages:
  display: !include packages/disp_conf.yaml
  color: !include packages/colors.yaml
  font: !include fonts/fonts.yaml
  disp_lambda: !include "packages/testesp-1/disp_lambda.yaml"
Seems Like the Indent required by the Lamba is causing the Issue.
How do I best Accheive this?
