Move Riemann sum integrations from yaml to graphic interface
Is it possible to move my Riemann sum integrations from yaml and convert them to helpers instead?
Best regards
Marcus
Yes but only manually. Delete the yaml, restart, then recreate the sensors in the UI. Unless you copy the entity_id exactly you will loose your history.
