Looked through path settings, adjusted and fixed, still no go.
Anyone understand this one?
Worked like a charm on the pi-distro.
device_tracker:
- platform: aruba
host: 10.7.0.101
username: admin
password: XXXXXX
16-11-13 14:06:07 homeassistant.components.device_tracker: Error setting up platform aruba
File “C:\Users\einar\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker_init_.py”, line 136, in setup_platform
scanner = platform.get_scanner(hass, {DOMAIN: p_config})
File “C:\Users\einar\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\aruba.py”, line 40, in get_scanner
scanner = ArubaDeviceScanner(config[DOMAIN])
File “C:\Users\einar\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\aruba.py”, line 59, in init
data = self.get_aruba_data()
File “C:\Users\einar\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\aruba.py”, line 97, in get_aruba_data
ssh = pexpect.spawn(connect.format(self.username, self.host))
AttributeError: module ‘pexpect’ has no attribute ‘spawn’
16-11-13 14:06:10 homeassistant.core: Error inside async loop: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF…\xa0\x02\x00’>)
16-11-13 14:06:11 homeassistant.components.recorder: Ended unfinished session (id=53 from 2016-11-13 13:02:09.887275)
16-11-13 14:06:11 homeassistant.components.recorder: Found unfinished sessions
Best regards
Snowy
