Moved HA to new location can access via app but not browser
Moved an HA Green to my mums house, laptop and phone on same SSID, HA plugged into ethernet, can connect via app and not browser. When access ip on browser can see login but it won’t accept un/pw, not changed either. Any clues folks as stumped here.
What is the IP of
  • HA Green
  • Phone
  • Laptop
    Make sure they are all in the same IP range
Thanks, really helpful. I got it working in the end needed to create a new login and then all good so far with that set to admin. Trying to get remote access in the app the next challenge :smiley:
I believe the issue is with cached credential/information in your browser. I assume you had already logged in to HA from that same browser before you moved the server?
If you clear out cookies and local storage, it would have likely worked with your original login. I think you could even try a ctrl-reload w/out clearing storage, but not certain.
