I just moved to Docker from HA OS and restored my setup by moving the files from /config over. Most things are working but I’m getting errors with recorder starting now. Originally I tried setting up a MariaDB container and updating the recorder
entry in configuration.yaml
but couldn’t get it to work. I decided to just go back to the stock recorder for now by removing the recorder
entry, but still got the same errors in my logs. I also tried removing the home-assistant_v2.db
file but no luck. Here’s what I’m seeing in the logs:
2023-01-26 15:45:49.702 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2023-01-26 15:46:14.747 ERROR (Recorder) [homeassistant.components.recorder.core] Error during connection setup: (MySQLdb.OperationalError) (2005, "Unknown MySQL server host 'core-mariadb' (-3)")
(Background on this error at: https://sqlalche.me/e/14/e3q8) (retrying in 3 seconds)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3361, in _wrap_pool_connect
return fn()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 325, in connect
return _ConnectionFairy._checkout(self)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 888, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 491, in checkout
rec = pool._do_get()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 145, in _do_get
with util.safe_reraise():
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/langhelpers.py", line 70, in __exit__
compat.raise_(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/compat.py", line 210, in raise_
raise exception
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 143, in _do_get
return self._create_connection()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 271, in _create_connection
return _ConnectionRecord(self)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 386, in __init__
self.__connect()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 684, in __connect
compat.raise_(
raise exception
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 680, in __connect
self.dbapi_connection = connection = pool._invoke_creator(self)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/create.py", line 578, in connect
return dialect.connect(*cargs, **cparams)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 598, in connect
return self.dbapi.connect(*cargs, **cparams)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/__init__.py", line 123, in Connect
return Connection(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/connections.py", line 185, in __init__
super().__init__(*args, **kwargs2)
MySQLdb.OperationalError: (2005, "Unknown MySQL server host 'core-mariadb' (-3)")
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 703, in _setup_recorder
self._setup_connection()
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1162, in _setup_connection
Base.metadata.create_all(self.engine)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/schema.py", line 4930, in create_all
bind._run_ddl_visitor(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 341, in _run_ddl_visitor
with self.begin() as conn:
File "/usr/local/lib/python3.10/contextlib.py", line 135, in __enter__
return next(self.gen)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 379, in begin
with self.connect() as conn:
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 406, in connect
return super(Engine, self).connect()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3315, in connect
return self._connection_cls(self, close_with_result=close_with_result)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 96, in __init__
else engine.raw_connection()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3394, in raw_connection
return self._wrap_pool_connect(self.pool.connect, _connection)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3364, in _wrap_pool_connect
Connection._handle_dbapi_exception_noconnection(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2198, in _handle_dbapi_exception_noconnection
util.raise_(
raise exception
return fn()
compat.raise_(
raise exception
self.__connect()
compat.raise_(
raise exception
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (2005, "Unknown MySQL server host 'core-mariadb' (-3)")
2023-01-26 15:46:39.500 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2023-01-26 15:46:52.796 ERROR (Recorder) [homeassistant.components.recorder.core] Error during connection setup: (MySQLdb.OperationalError) (2005, "Unknown MySQL server host 'core-mariadb' (-3)")
return fn()
compat.raise_(
raise exception
self.__connect()
compat.raise_(
raise exception
util.raise_(
raise exception
return fn()
compat.raise_(
raise exception
self.__connect()
compat.raise_(
raise exception
