Moving binary_sensor entries to files not working
In my HA configuration.yaml file, I have the following entries:
binary_sensor:
  - platform: trend
    sensors:
      masterbath_humidity_rising:
        entity_id: sensor.masterbath_humidity
        sample_duration: 600
        max_samples: 20
        min_gradient: 0.05
        device_class: moisture
  - platform: trend
    sensors:
      masterbath_humidity_stable_up:
        max_samples: 100
        min_gradient: 0.00833333333
        invert: true
  - platform: trend
    sensors:
      masterbath_humidity_stable_down:
        max_samples: 100
        min_gradient: -0.00833333333
        invert: true
I want to move them to their own file, so I deleted them and at the top of the file I put the following setting:
binary_sensor: !include_dir_merge_list ./sensor/binary/
and then I created a file in ./sensor/binary/ called humidity_trends.yaml and put the following lines in that file:
- platform: trend
  sensors:
      max_samples: 20
      min_gradient: 0.05
- platform: trend
  sensors:
      max_samples: 100
      invert: true
- platform: trend
  sensors:
      max_samples: 100
      invert: true
HA “check configuration” shows no problems. Restart HA and now my automations where I use those sensors I get error “Error in describing trigger: Cannot read properties of undefined entity id”
Generally, how does one move
binary_sensor:
to files?
Use packages.
