Hi
In the past, I’ve been running my ConBee III stick from Dresden Elektronik with Phoscon on a Raspberry PI with Homebridge (via USB on the Raspberry Pi). Using the deConz Home Assistant integration, I can see all my devices in Home Assistant, and everything’s working perfectly so far. Since I now run almost everything in Home Assistant and may not need Homebridge for a while, I’m considering connecting the stick directly to the Raspberry PI running Home Assistant (a separate Raspberry Pi).
Now my question: What happens if I simply plug the stick from one Raspberry Pi to another (from Homebridge to Home Assistant)? Does anyone have experience with this? Will everything continue to work, or do I have to reconfigure everything?
Thanks & best Regards
Stefan
