Moving FGS223 devices from VeraPlus
I am new to Home Assistant, I tried a few years ago to move from VeraPlus but at the end didn’t do it, so I am trying again.
Since most of my devices are inside the walls, it is hard to exclude and include them.
I copied the Z-Wave configuration to my Aeotec 5 stick and most devices were identified correctly, however a few FGS223 devices appears without their control buttons , I tried to re-interview one of them (Node 022), and here is part of the debug information, can anyone identify the issue ? Is there a resolution beside exclude/include ?
2026-01-17 09:49:47.144 CNTRLR   [Node 022] Beginning interview - last completed stage: None
2026-01-17 09:49:47.147 CNTRLR   [Node 022] new node, doing a full interview...
2026-01-17 09:49:47.155 CNTRLR » [Node 022] querying protocol info...
2026-01-17 09:49:47.164 DRIVER   one or more queues busy
2026-01-17 09:49:47.168 DRIVER » [REQ] [GetNodeProtocolInfo]
2026-01-17 09:49:47.171 SERIAL » 0x0104004116ac                                                       (6 bytes)
2026-01-17 09:49:47.177 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:47.181 SERIAL « 0x01090141d39c01041001ed                                            (11 bytes)
2026-01-17 09:49:47.189 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.192 DRIVER « [RES] [GetNodeProtocolInfo]
2026-01-17 09:49:47.196 CNTRLR « [Node 022] received response for protocol info:
                                 basic device class:    Routing End Node
                                 generic device class:  Binary Switch
                                 specific device class: Binary Power Switch
                                 node type:             End Node
                                 is always listening:   true
                                 is frequent listening: false
                                 can route messages:    true
                                 supports security:     false
                                 supports beaming:      true
                                 maximum data rate:     100000 kbps
                                 protocol version:      3
2026-01-17 09:49:47.204 CNTRLR   [Node 022] Interview stage completed: ProtocolInfo
2026-01-17 09:49:47.207 CNTRLR » [Node 022] pinging the node...
2026-01-17 09:49:47.215 DRIVER » [Node 022] [REQ] [SendData]
                                 │ transmit options: 0x01
                                 │ callback id:      149
                                 └─[NoOperationCC]
2026-01-17 09:49:47.218 SERIAL » 0x01080013160100019567                                              (10 bytes)
2026-01-17 09:49:47.224 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:47.230 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:47.234 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.237 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:47.284 SERIAL « 0x011800139500000601d77f7f7f7f0101030c00000002010000bd              (26 bytes)
2026-01-17 09:49:47.288 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.293 DRIVER « [REQ] [SendData]
                                   callback id:            149
                                   transmit status:        OK, took 60 ms
                                   repeater node IDs:      12
                                   routing attempts:       1
                                   protocol & route speed: Z-Wave, 40 kbit/s
                                   routing scheme:         LWR
                                   ACK RSSI:               -41 dBm
                                   ACK RSSI on repeaters:  N/A
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:47.303 CNTRLR   [Node 022] The node is alive.
2026-01-17 09:49:47.310 CNTRLR « [Node 022] ping successful
2026-01-17 09:49:47.316 CNTRLR » [Node 022] querying node info...
2026-01-17 09:49:47.328 DRIVER » [Node 022] [REQ] [RequestNodeInfo]
                                   node id: 22
2026-01-17 09:49:47.332 SERIAL » 0x01040060168d                                                       (6 bytes)
2026-01-17 09:49:47.338 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:47.345 SERIAL « 0x01040160019b                                                       (6 bytes)
2026-01-17 09:49:47.350 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.353 DRIVER « [RES] [RequestNodeInfo]
                                   was sent: true
2026-01-17 09:49:47.483 SERIAL « 0x0114004984160e0410015e8672597322563271987a7e                      (22 bytes)
2026-01-17 09:49:47.490 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.493 DRIVER « [Node 022] [REQ] [ApplicationUpdateRequest]
2026-01-17 09:49:47.496 CNTRLR « [Node 022] node info received
                                 supported CCs:
                                 · Z-Wave Plus Info
                                 · Version
                                 · Manufacturer Specific
                                 · Association Group Information
                                 · Powerlevel
                                 · Application Status
                                 · CRC-16 Encapsulation
                                 · Meter
                                 · Notification
                                 · Security
                                 · Firmware Update Meta Data
2026-01-17 09:49:47.499 CNTRLR « [Node 022] node info received
                                 supported CCs:
                                 · Z-Wave Plus Info
                                 · Version
                                 · Powerlevel
                                 · Meter
                                 · Notification
                                 · Security
2026-01-17 09:49:47.506 CNTRLR   [Node 022] Interview stage completed: NodeInfo
2026-01-17 09:49:47.522 CNTRLR   [Node 022] Interviewing Manufacturer Specific...
2026-01-17 09:49:47.524 CNTRLR » [Node 022] querying manufacturer information...
2026-01-17 09:49:47.561 DRIVER » [Node 022] [REQ] [SendData]
                                 │ transmit options: 0x25
                                 │ callback id:      150
                                 └─[ManufacturerSpecificCCGet]
2026-01-17 09:49:47.564 SERIAL » 0x0109001316027204259634                                            (11 bytes)
2026-01-17 09:49:47.571 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:47.578 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:47.584 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.587 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:47.634 SERIAL « 0x011800139600000601d07f7f7f7f0101030c00000002010000b9              (26 bytes)
2026-01-17 09:49:47.639 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.642 DRIVER « [REQ] [SendData]
                                   callback id:            150
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -48 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:47.707 SERIAL « 0x011000040016087205010f02031000d0004d                              (18 bytes)
2026-01-17 09:49:47.712 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.716 CNTRLR   [Node 022] [Manufacturer Specific] productId: metadata updated    [Endpoint 0]
2026-01-17 09:49:47.722 CNTRLR   [Node 022] [+] [Manufacturer Specific] productId: 4096            [Endpoint 0]
2026-01-17 09:49:47.727 CNTRLR   [Node 022] [Manufacturer Specific] productType: metadata updated  [Endpoint 0]
2026-01-17 09:49:47.732 CNTRLR   [Node 022] [+] [Manufacturer Specific] productType: 515           [Endpoint 0]
2026-01-17 09:49:47.737 CNTRLR   [Node 022] [Manufacturer Specific] manufacturerId: metadata updat [Endpoint 0]
                                 ed
2026-01-17 09:49:47.743 CNTRLR   [Node 022] [+] [Manufacturer Specific] manufacturerId: 271        [Endpoint 0]
2026-01-17 09:49:47.748 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                 └─[ManufacturerSpecificCCReport]
                                     manufacturer id: 0x010f
                                     product type:    0x0203
                                     product id:      0x1000
2026-01-17 09:49:47.753 CNTRLR « [Node 022] received response for manufacturer information:
                                   manufacturer: Nice Polska Sp. z o.o. (0x010f)
                                   product id:   0x1000
2026-01-17 09:49:47.763 CNTRLR   [Node 022] [+] [Manufacturer Specific] interviewComple [Endpoint 0] [internal]
                                 te: true
2026-01-17 09:49:47.769 CNTRLR   [Node 022] Interviewing Version...
2026-01-17 09:49:47.773 CNTRLR » [Node 022]   querying the CC version for Version...
2026-01-17 09:49:47.850 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      151
                                 └─[VersionCCCommandClassGet]
                                     CC: Version
2026-01-17 09:49:47.853 SERIAL » 0x010a00131603861386259752                                          (12 bytes)
2026-01-17 09:49:47.869 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:47.873 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:47.877 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.881 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:47.926 SERIAL « 0x011800139700000601d07f7f7f7f0101030c00000002010000b8              (26 bytes)
2026-01-17 09:49:47.930 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:47.933 DRIVER « [REQ] [SendData]
                                   callback id:            151
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -48 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:48.005 SERIAL « 0x010c000400160486148602d50026                                      (14 bytes)
2026-01-17 09:49:48.011 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.014 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                 └─[VersionCCCommandClassReport]
                                     CC:      Version
                                     version: 2
2026-01-17 09:49:48.018 CNTRLR   [Node 022]   supports CC Version (0x86) in version 2
2026-01-17 09:49:48.020 CNTRLR » [Node 022] querying node versions...
2026-01-17 09:49:48.028 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      152
                                 └─[VersionCCGet]
2026-01-17 09:49:48.031 SERIAL » 0x01090013160286112598db                                            (11 bytes)
2026-01-17 09:49:48.036 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:48.043 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:48.047 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.050 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:48.144 SERIAL « 0x011800139800000a01d07f7f7f7f0101030c00000002010000bb              (26 bytes)
2026-01-17 09:49:48.148 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.151 DRIVER « [REQ] [SendData]
                                   callback id:            152
                                   transmit status:        OK, took 100 ms
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -48 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:48.218 SERIAL « 0x01110004001609861203040503020300d000b1                            (19 bytes)
2026-01-17 09:49:48.226 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.230 CNTRLR   [Node 022] [Version] hardwareVersion: metadata updated            [Endpoint 0]
2026-01-17 09:49:48.235 CNTRLR   [Node 022] [+] [Version] hardwareVersion: 3                       [Endpoint 0]
2026-01-17 09:49:48.241 CNTRLR   [Node 022] [Version] firmwareVersions: metadata updated           [Endpoint 0]
2026-01-17 09:49:48.246 CNTRLR   [Node 022] [+] [Version] firmwareVersions: 3.2                    [Endpoint 0]
2026-01-17 09:49:48.252 CNTRLR   [Node 022] [Version] protocolVersion: metadata updated            [Endpoint 0]
2026-01-17 09:49:48.257 CNTRLR   [Node 022] [+] [Version] protocolVersion: "4.5"                   [Endpoint 0]
2026-01-17 09:49:48.263 CNTRLR   [Node 022] [Version] libraryType: metadata updated                [Endpoint 0]
2026-01-17 09:49:48.268 CNTRLR   [Node 022] [+] [Version] libraryType: 3                           [Endpoint 0]
2026-01-17 09:49:48.274 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                 └─[VersionCCReport]
                                     library type:      Enhanced Slave
                                     protocol version:  4.5
                                     firmware versions: 3.2
                                     hardware version:  3
2026-01-17 09:49:48.278 CNTRLR « [Node 022] received response for node versions:
                                   library type:      Enhanced Slave (0x03)
                                   hardware version:  3
2026-01-17 09:49:48.281 CNTRLR » [Node 022] querying CC versions...
2026-01-17 09:49:48.284 CNTRLR » [Node 022]   querying the CC version for Basic...
2026-01-17 09:49:48.293 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      153
                                     CC: Basic
2026-01-17 09:49:48.297 SERIAL » 0x010a001316038613202599fa                                          (12 bytes)
2026-01-17 09:49:48.307 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:48.313 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:48.317 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.320 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:48.373 SERIAL « 0x011800139900000601d77f7f7f7f0101030c00000002010000b1              (26 bytes)
2026-01-17 09:49:48.377 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.381 DRIVER « [REQ] [SendData]
                                   callback id:            153
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -41 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:48.446 SERIAL « 0x010c000400160486142001d00086                                      (14 bytes)
2026-01-17 09:49:48.450 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.453 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                     CC:      Basic
                                     version: 1
2026-01-17 09:49:48.456 CNTRLR   [Node 022]   supports CC Basic (0x20) in version 1
2026-01-17 09:49:48.459 CNTRLR » [Node 022]   querying the CC version for Z-Wave Plus Info...
2026-01-17 09:49:48.466 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      154
                                     CC: Z-Wave Plus Info
2026-01-17 09:49:48.469 SERIAL » 0x010a0013160386135e259a87                                          (12 bytes)
2026-01-17 09:49:48.474 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:48.480 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:48.483 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.487 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:48.584 SERIAL « 0x011800139a00000b01d07f7f7f7f0101030c00000002010000b8              (26 bytes)
2026-01-17 09:49:48.589 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.594 DRIVER « [REQ] [SendData]
                                   callback id:            154
                                   transmit status:        OK, took 110 ms
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -48 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:48.656 SERIAL « 0x010c000400160486145e02d000fb                                      (14 bytes)
2026-01-17 09:49:48.660 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.663 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                     version: 2
2026-01-17 09:49:48.666 CNTRLR   [Node 022]   supports CC Z-Wave Plus Info (0x5e) in version 2
2026-01-17 09:49:48.669 CNTRLR » [Node 022]   querying the CC version for Manufacturer Specific...
2026-01-17 09:49:48.675 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      155
                                     CC: Manufacturer Specific
2026-01-17 09:49:48.678 SERIAL » 0x010a00131603861372259baa                                          (12 bytes)
2026-01-17 09:49:48.683 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:48.689 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:48.694 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.697 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:48.794 SERIAL « 0x011800139b00000b01d07f7f7f7f0101030c00000002010000b9              (26 bytes)
2026-01-17 09:49:48.798 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.801 DRIVER « [REQ] [SendData]
                                   callback id:            155
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -48 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:48.865 SERIAL « 0x010c000400160486147202d500d2                                      (14 bytes)
2026-01-17 09:49:48.869 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.872 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                     version: 2
2026-01-17 09:49:48.876 CNTRLR   [Node 022]   supports CC Manufacturer Specific (0x72) in version 2
2026-01-17 09:49:48.878 CNTRLR » [Node 022]   querying the CC version for Association Group Information...
2026-01-17 09:49:48.885 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      156
                                     CC: Association Group Information
2026-01-17 09:49:48.888 SERIAL » 0x010a00131603861359259c86                                          (12 bytes)
2026-01-17 09:49:48.893 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:48.899 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:48.902 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:48.906 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:49.004 SERIAL « 0x011800139c00000b01ca7f7f7f7f0101030c00000002010000a4              (26 bytes)
2026-01-17 09:49:49.007 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:49.011 DRIVER « [REQ] [SendData]
                                   callback id:            156
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -54 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:49.075 SERIAL « 0x010c000400160486145901d500fa                                      (14 bytes)
2026-01-17 09:49:49.079 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:49.083 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                     version: 1
2026-01-17 09:49:49.086 CNTRLR   [Node 022]   supports CC Association Group Information (0x59) in version 1
2026-01-17 09:49:49.088 CNTRLR » [Node 022]   querying the CC version for Powerlevel...
2026-01-17 09:49:49.095 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      157
                                     CC: Powerlevel
2026-01-17 09:49:49.098 SERIAL » 0x010a00131603861373259dad                                          (12 bytes)
2026-01-17 09:49:49.103 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:49.111 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:49.115 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:49.118 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:49.214 SERIAL « 0x011800139d00000b01d07f7f7f7f0101030c00000002010000bf              (26 bytes)
2026-01-17 09:49:49.218 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:49.222 DRIVER « [REQ] [SendData]
                                   callback id:            157
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -48 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1
2026-01-17 09:49:49.288 SERIAL « 0x010c000400160486147301d500d0                                      (14 bytes)
2026-01-17 09:49:49.292 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:49.295 DRIVER « [Node 022] [REQ] [ApplicationCommand]
                                     CC:      Powerlevel
                                     version: 1
2026-01-17 09:49:49.299 CNTRLR   [Node 022]   supports CC Powerlevel (0x73) in version 1
2026-01-17 09:49:49.301 CNTRLR » [Node 022]   querying the CC version for Application Status...
2026-01-17 09:49:49.308 DRIVER » [Node 022] [REQ] [SendData]
                                 │ callback id:      158
                                     CC: Application Status
2026-01-17 09:49:49.311 SERIAL » 0x010a00131603861322259eff                                          (12 bytes)
2026-01-17 09:49:49.317 SERIAL « [ACK]        (0x06)
2026-01-17 09:49:49.323 SERIAL « 0x0104011301e8                                                       (6 bytes)
2026-01-17 09:49:49.327 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:49.329 DRIVER « [RES] [SendData]
                                   was sent: true
2026-01-17 09:49:49.424 SERIAL « 0x011800139e00000a01d77f7f7f7f0101030c00000002010000ba              (26 bytes)
2026-01-17 09:49:49.428 SERIAL » [ACK]        (0x06)
2026-01-17 09:49:49.432 DRIVER « [REQ] [SendData]
                                   callback id:            158
                                   routing attempts:       1
                                   routing scheme:         LWR
                                   ACK RSSI:               -41 dBm
                                   ACK channel no.:        1
                                   TX channel no.:         1```
Latest firmware?
On the Aeotec stick I am using the latest, for the Fibaro module I am not sure, but in any case OTA is only possible using Fibaro hub which I don’t have.
BTW - is there a way to upload the entire log?
Update:
I had re-interviewed the node but this time selected the clear security. In addition during the interview I press the physical switch.
The interview took longer but after that the control entity appeared and I was able to turn on and off the lights.
