Moving hardware - Keep config?
As suggested I’m replacing my RPI4-1G by MINIPC. Will also do it with Virtualization cause I need that PC for other purpose.
I would love to avoid having to repair all my zigbee devices/wifi (MQTT2ZB) and calendar and automations. Is there a way to bring this or better the whole config over ?
thanks!
Like I hinted at in the other thread, you just need to upload a backup from your current install. :wink:
Z2MQTT should continue where it left off, especially if your coordinator is defined using serial by id.
If you’re going with virtualization, I highly suggest proxmox. There’s an excellent guide with easy to follow steps here if you search for it.
Sounds good, just tried and it worked!
Big thanks!
