The most recent HA blog states
One of the directions we care about most for Home Assistant is making it simpler to pick up and use, without compromising on capability. It’s something we have been working toward for a long time, and it runs through our roadmap and goals for this year. We cannot do it overnight though, so we keep listening to your feedback to make sure we are fixing the things that actually get in your way. If there is something you would like to see, we would love for you to weigh in. Every comment helps shape what comes next.
So here’s mine:
If I have two views in Lovelace (Home and Office) and I have a card on Home that I now want to be on Office instead, it should be simple and easy to move it.
It is not.
First, after entering edit mode, I try dragging the card to the Office tab. The drag is rejected — it should be accepted and the card moved to the last place on the Office page. (Bonus point for “spring-loading” it, where hovering over the tab for a second or two opens the tab and then you can drop the card exactly where you want it. I suspect macOS’s drag handling is spoiling me there, though
Second, I click on the three dots of the card. I should see a “Move To…” menu item. There isn’t one. There should be, and it should work the same way as dragging to the tab.
Third, I see that there is “Copy” (and “Cut” for braver souls). I click it, then navigate to the Office page. I press ⌘V. Nothing happens.
I click the “add card” button, expecting to see a message saying that there’s a card on the clipboard, and asking if I want to paste it. I don’t. I press ⌘V. The previous clipboard entry is pasted into the search box — HA doesn’t even seem to have copied anything!
I’m sure I have copied things elsewhere in HA, then gone to an “add” dialog and it’s detected that the clipboard has something relevant and offered to paste that. I wish I could remember where so I could give an example. But that’s what needs to happen here.
To move a card, I have to:
- Edit the card
- Go into the code editor
- Copy the YAML
- Go to the destination
- Create a new card of the same type
- Paste the copied YAML over the top of the existing YAML
- Save
- Go back to the original page
- Delete the old card
WTH is this so complicated? Does everyone else always put things in the right place and never need to move them? Or is there some way of actually doing this easily that’s just very well concealed and not at all intuitive?
Bonus WTH: if you’re running the “native” app on macOS, copy DOESN’T WORK AT ALL. Not even if you select some text and hit ⌘C — you have to access HA in a browser if you want to copy stuff. ⌘C doesn’t work, the “copy” buttons in the UI don’t work — nothing does.
(Apparently the “native” macOS app is actually the iOS app running under some layer that Apple’s provided, and in true Apple style they haven’t bothered to make it Just Work™ because “it’s only the Mac, it doesn’t matter any more; go and add new features to iOS intead of fixing bugs on macOS”.
It would be lovely if the Mac HA app was actually Mac-native and didn’t keep trying to act like it was on an iPad…)
My apologies for the rantiness, but this is incredibly frustrating. I can’t be the only person who’s having trouble here — can I?
