Moving to the SONOFF 3.0 USB stick Zigbee2mqtt
I’m trying to move from a Conbee II stick to a flashed SONOFF 3.0 stick.
The thing i’m stuck at is removing the database… i just cannot find it.
I looked at the guide but unable to find that path or even that file when i look in the config and zigbee2mqtt folders.
https://www.zigbee2mqtt.io/guide/faq/#how-do-i-migrate-from-one-adapter-to-another
I am using HA core 2022.3.3 / OS 7.4
Where should i be looking?
Found out the file is hidden, so using elevated SSH fixed that.
But after following the steps the addon will throw a fit about panid, and if i change that all the devices go missing.
Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
Anyone here did a successful coördinator swap?
