Moving to Z-Wave JS - Facing addon startup error
I have been trying to replace the old Z-Wave integration (thorugh configuration file) to Z-Wave JS. I deleted the lines in configuration file and deleted the old integration.
I installed the Zwave JS addon but when running the addon I get this error:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] config.sh: executing...
[cont-init.d] config.sh: exited 0.
[cont-init.d] structure.sh: executing...
[cont-init.d] structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:59:31] INFO: Successfully send discovery information to Home Assistant.
21:59:41.464 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
21:59:41.506 DRIVER   version 6.5.0
21:59:41.509 DRIVER
This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
ZWaveError: The config has not been loaded yet!
    at ConfigManager.lookupSensorType (/usr/lib/node_modules/zwave-js/node_modules/@zwave-js/config/src/ConfigManager.ts:277:10)
    at ConfigManager.lookupSensorScale (/usr/lib/node_modules/zwave-js/node_modules/@zwave-js/config/src/ConfigManager.ts:288:23)
    at new MultilevelSensorCCReport (/usr/lib/node_modules/zwave-js/src/lib/commandclass/MultilevelSensorCC.ts:408:43)
    at new CommandClass (/usr/lib/node_modules/zwave-js/src/lib/commandclass/CommandClass.ts:108:13)
    at new MultilevelSensorCC (/usr/lib/node_modules/zwave-js/src/lib/commandclass/MultilevelSensorCC.ts:205:1)
    at Function.from (/usr/lib/node_modules/zwave-js/src/lib/commandclass/CommandClass.ts:331:15)
    at new ApplicationCommandRequest (/usr/lib/node_modules/zwave-js/src/lib/controller/ApplicationCommandRequest.ts:88:32)
    at Function.from (/usr/lib/node_modules/zwave-js/src/lib/message/Message.ts:222:15)
    at Driver.serialport_onData (/usr/lib/node_modules/zwave-js/src/lib/driver/Driver.ts:1395:18)
    at SerialAPIParser.emit (events.js:315:20)
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Any help will be apreciated
you already posted this in another thread.
see the answer there.
There is an open issue for this
