Hi, i am in between moving from domoticz to ha. There os one thing i do not know how it works - zwave.i had troubles with it from the beggining. I have aoetec stick and some devices - blind controller/switches. My question is : can i move my aoetec stick to raspberry with ha ? Will it still work ? Will i need to reconnect devices or the configurations stick to the aoetec stick ?
Hi.
You don’t have to pair or include the device again with your aeon tech stick.
But it usually takes a littlebit of tinkering before open zwave in HA has downloaded and discovered all your devices.
But when that is up and running you can move your aoen stick back and forth between the HA and domoticzs.
I used a new raspberry (rpi3) my HA. When tested HA and configured it I moved my usb stick to that raspberry. When I got tired on tinkering I moved it back to domoticzs and restarted it worked as before. When you are satisfied with your HA you can retire your domoticzs system.
Thanks for the the replay. Right now domoticz serves me only for z wave. I will try it later i have installed ha on raspberry in virtual envvironment, do i need to install anything regarding zwave manually ?
