MQQT connections from unknown IP outside my subnet
My mqqt log has a string of entries as follows:
1651787664: New connection from 172.30.32.1:56840 on port 1883.
1651787664: New client connected from 172.30.32.1:56840 as auto-A0B0C05F-D9BA-8821-AC21-1186A3C3E7BF (p2, c1, k60, u'mqqt-user').
1651787664: Client auto-A0B0C05F-D9BA-8821-AC21-1186A3C3E7BF closed its connection.
1651787695: New connection from 172.30.32.1:56916 on port 1883.
1651787695: New client connected from 172.30.32.1:56916 as auto-134CAC54-2A14-37B3-0199-5F81B678A9A9 (p2, c1, k60, u'mqqt-user').
1651787695: Client auto-134CAC54-2A14-37B3-0199-5F81B678A9A9 closed its connection.
1651787718: New connection from 172.30.32.2:35968 on port 1883.
my subnet is 192.168.0.0/24. I’ve been using Zerotier for remote access so no ports are open on my router, firewall is enabled. These IP addresses don’t match my Zerotier subnet either.
Any idea what this could be?
I’m using the Mosquitto mqqt broker, only mqqt devices I’ve installed (to my knowledge) are the Ring doorbell and Hisense AC integration - Ring is working, Hisense is not for some reason.
This is the network IP range that Home Assistant docker containers use.
Nothing to worry about.
Ah, ok. Thanks !
