MQTT and Shelly can't connect
Hi everyone,
I have MQTT Brokwer installed and the MQTT Integration enabled.
I can confirm it works because the “HoyMiles Solar Gateway stable Addon” is able to connect.
I have created a user “mqtest” which is allowed to have “local network logins only” and has a password of “abcdefg”.
In Integrations → MQTT → Re-configure:
Broker: core-mosquitto
Port: 1883
user: mqtest
pw: abcdefg
In the MQTT Options I have enabled discovery, birth messsage and will message.
For the Shelly 3EM Pro I configured it like this:
MQTT: Enable
Connection type: No TLS
MQTT prefix: shellypro3em_123456
Enable MQTT Control
Enable RPC over MQTT
Enable RPC Status notifications over MQTT
Enable Generic status update over MQTT
Server: IP_of_HA_Green_device:1883
Client ID: shellypro3em-123456 (I didn’t change this)
user: mqtest
pw: abcdefg
The HA MQTT Explorer doesn’t show any connection of the Shelly.
Additionally the Shelly created two entities with this script:
let energyReturnedWs = 0.0;
let energyConsumedWs = 0.0;
let energyReturnedKWh = 0.0;
let energyConsumedKWh = 0.0;
let log = 0;
// set this to false to stop publishing on MQTT
let MQTTpublish = true;
// set this to false if you DONT want to update the name
// (the updated name is necessary to read the data with the iobroker shelly plugin)
let updateName = false;
// query the MQTT prefix on startup
let SHELLY_ID = undefined;
Shelly.call("Mqtt.GetConfig", "", function (res, err_code, err_msg, ud) {
  SHELLY_ID = res["topic_prefix"];
function SetKVS(key, value)
 Shelly.call(
   "KVS.Set", {
     "key": key,
     "value": value,
   function(result) {
     if (log > 0)
       print("KVS Saved, rev:", result.rev);
function SaveCounters()
  SetKVS("EnergyConsumedKWh", energyConsumedKWh );
  SetKVS("EnergyReturnedKWh", energyReturnedKWh );
Shelly.call(
   "KVS.Get", {
     "key": "EnergyReturnedKWh",
  function callback(result, error_code, error_message, userdata) {
     if (error_code === 0)
       energyReturnedKWh = Number(result.value);
       print("Loaded returned energy: ", energyReturnedKWh, " KWh");
 Shelly.call(
   "KVS.Get", {
     "key": "EnergyConsumedKWh",
       energyConsumedKWh = Number(result.value);
       print("Loaded consumed energy: ", energyConsumedKWh, " KWh");
let counter3600 = 0;
let counter20 = 18;
let lastPublishedMQTTConsumed = "";
let lastPublishedMQTTReturned = "";
function timerHandler(user_data)
  let em = Shelly.getComponentStatus("em", 0);
  if (typeof em.total_act_power !== 'undefined') {
    let power = em.total_act_power;
    if (power >= 0)
        energyConsumedWs = energyConsumedWs + power * 0.5;
    else
        energyReturnedWs = energyReturnedWs - power * 0.5;
    // once a full Wh is accumulated, move it to the KWh counter
    let fullWh = Math.floor((energyConsumedWs / 3600));
    if (fullWh > 0)
      energyConsumedKWh += fullWh / 1000;
      energyConsumedWs -= fullWh * 3600;
      if (log > 0)
        print("Changed consumed KWh: ",energyConsumedKWh);
    fullWh = Math.floor((energyReturnedWs / 3600));
    if (fullWh > 0)
      energyReturnedKWh += fullWh / 1000;
      energyReturnedWs -= fullWh * 3600;
      if (log > 0)
        print("Changed returned KWh: ",energyReturnedKWh);
    if (log > 0)
      print(power , "W");
    counter3600 = counter3600 + 1;
    if (counter3600 > 3600)
      counter3600 = 0;
      SaveCounters();
    counter20 = counter20 + 1;
    if ( counter20 > 20)
      counter20 = 0;
      if (updateName)
        Shelly.call(
          "Sys.SetConfig", {
             config: {device:{name:energyConsumedKWh.toFixed(3)+" KWh ; "+(energyReturnedKWh+energyReturnedWs / 3600000).toFixed(5)+" KWh"}},
          function(result, error_code, error_message, userdata) {
             //print("error ", error_code, " : ", error_message);
             //print("result", JSON.stringify(result));
      if (typeof SHELLY_ID !== "undefined" && MQTTpublish === true)
        let value = energyConsumedKWh.toFixed(3);
        if (value !== lastPublishedMQTTConsumed)
          MQTT.publish(
            SHELLY_ID + "/energy_counter/consumed",
            value,
            0,
            false
          lastPublishedMQTTConsumed = value;
        let value = energyReturnedKWh.toFixed(3);
        if (value !== lastPublishedMQTTReturned)
          MQTT.publish(
            SHELLY_ID + "/energy_counter/returned",
            value,
            0,
            false
          lastPublishedMQTTReturned = value;
Timer.set(500, true, timerHandler, null);
function httpServerHandler(request, response) {
    response.code = 200;
    // create JSON object
    const energyData = {
        energyConsumed: energyConsumedKWh.toFixed(3) + " KWh",
        energyReturned: (energyReturnedKWh+(energyReturnedWs / 3600000)).toFixed(5) + " KWh"
    // convert JSON object to string and send it as reply
    response.body = JSON.stringify(energyData);
    response.send();
    return;
HTTPServer.registerEndpoint("energy_counter", httpServerHandler);
While in my configurations.yaml I created these sensors:
mqtt:
    - name: shellypro3em_123456-diff_total_energy-consumed
      unique_id: shellypro3em_123456-c
      state_topic: "shellypro3em_123456/energy_counter/consumed"
      unit_of_measurement: "kWh"
      state_class: total_increasing
      device_class: energy
    - name: shellypro3em_123456-diff_total_energy-returned
      unique_id: shellypro3em_123456-r
      state_topic: "shellypro3em_123456/energy_counter/returned"
The entitiy “shellypro3em_123456-diff_total_energy-consumed” is unknown.
It seems like the shelly doesn’t connect via MQTT at all.
Does anyone have hints on why this isn’t working?
THanks!
Hey, have you found a solution? i’m having the same issue with a Shelly1Gen4, I can’t seem tot integrate it into Zigbee2MQTT. I can find the Shelly1Gen4 in the Shelly integration, but i want to install some in wifi-dead-zones as well. Not beeing able to use the zigbee routers is blocking this approach.
