Hi.
I’m having some trouble using the mosquitto broker add-on, and was hoping anyone had some suggestions. I’ve tried to solve it for several days without luck.
Background ;
Moved from RPi running Home Assistant + mosquitto (not add-on)
Moved to Win 10 machine running VBox Home Assistant incl Mosquitto add-on
I have Sonoff Bridge, Zigbee2mqtt and some ESP8266/ESP32 communicating through mqtt.
The ESP’s are not running ESPHome.
Everything except the ESP’s are working fine in the MQTT add-on. ESP will connect, but not publish. I also get “exceeded timeout, disconnecting”, but this seems to go away if I use mqtt_username + mqtt_password in the code.
I set up a RPi with mosquitto broker for testing the ESP’s and as long as I run mosquitto on Pi it works.
I tried port forward of port 1883, tried disabling win 10 firewall and tried different config’s in the mosquitto broker add-on without luck.
This is serial print in Arduino IDE, no publish message between connection and heartbeat.
WiFi connected
IP address:
192.168.esp.ip
Attempting MQTT connection...connected
20 second heartbeat: mqtt alive
This is config in mosquitto broker add-on. Username and password is same as in HA, and Arduino code. I also tried with anonymous false + removed user from acl, and active false
logins:
- username: user
password: password
anonymous: true
customize:
active: true
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
MQTT settings
Broker: core-mosquitto
Port: 1883
Username: same as add-on/arduino
Password: same as add-on/arduino
ESP8266 code :
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
// Update these with values suitable for your network.
#define LED 0 //GPIO16 is LED on my ESP8266 module
//"**CHANGE**" wifi SSID and password
const char* ssid = "SSID";
const char* password = "password";
//"**CHANGE**" MQTT server IP address
const char* mqtt_server = "192.168.HA.IP"; //mqtt server server 2.3
const char* mqtt_user = "user"; // same as in mqtt add-on config
const char* mqtt_password = "password"; // same as in mqtt add-on config
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
IPAddress server(192, 168, x, xx);
unsigned long heartbeat_millis=0;
int heartbeat_cnt=0;
//"**CHANGE**" debug output
#define MyDebug 0 //0=no debug, 1=deeebug
**CHANGE** mqtt_name[] used as part of topic name
/ble/MQTT_NAME/mac/rssi
/ble/MQTT_NAME/mac/volt
const char mqtt_name[]="2etg";
//const char mqtt_name[]="livingroom";
//const char mqtt_name[]="basement";
const int pinHandShake = 4; //handshake pin, esp8266 GPIO4/D2
//buffer for char[] used in mqtt publishes, size at least as big as topic + msg length
char mqtt_buf[120]; // e.g "/ble/esp1/d76dcd1b3720/volt" is 30 chars long
bool conn_status;
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
const int serialBufSize = 100; //size for at least the size of incoming JSON string
static char serialbuffer[serialBufSize]; // {"mac":c2f154bb0af9,"rssi":-55,"volt":3.05,"mag":1}
static char mytopic[120]; //MQTT topic string size, must be less than size declared.
//todo: add error checking for mqtt msg lengths
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
digitalWrite(LED, HIGH); //off
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
char message_buff[60]; //payload string
// create string for payload
int i=0;
for(i=0; i<length; i++)
message_buff[i] = payload[i];
message_buff[i] = '\0'; //terminate buffer string class eol
String msgString = String(message_buff);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client2-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str())) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("outTopic", "hello world");
// ... and resubscribe
//client.subscribe("inTopic");
//client.subscribe("50C51C570B00"); //switched ble
//client.subscribe("req_door_open");
//client.subscribe("req_door_close");
//client.subscribe("mq_snow_red");
//client.subscribe("mq_snow_green");
//client.subscribe("mq_snow_blue");
//client.subscribe("mq_tree_red");
//client.subscribe("mq_tree_green");
//client.subscribe("mq_tree_blue");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup() {
pinMode(LED, OUTPUT); // BUILTIN_LED pin as an output, actually pin D0 (GPIO16)
digitalWrite(LED, LOW); //LED on
Serial.begin(9600); //ESP8266 default serial on UART0 is GPIO1 (TX) and GPIO3 (RX)
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(pinHandShake, OUTPUT);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
//stealing this code from
//https://hackingmajenkoblog.wordpress.com/2016/02/01/reading-serial-on-the-arduino/
//non-blocking serial readline routine, very nice. Allows mqtt loop to run.
int readline(int readch, char *buffer, int len)
static int pos = 0;
int rpos;
if (readch > 0) {
switch (readch) {
case '\n': // Ignore new-lines
break;
case '\r': // Return on CR
rpos = pos;
pos = 0; // Reset position index ready for next time
return rpos;
default:
if (pos < len-1) {
buffer[pos++] = readch; //first buffer[pos]=readch; then pos++;
buffer[pos] = 0;
// No end of line has been found, so return -1.
return -1;
//json iterator that parses char* and publish each key-value pair as mqtt data
void localParseJson(char *mybuf)
//JSON parsing
//JSON object exists in this scope, routine should execute atomatically no interrupts
//If software serial is used, and parsing is interrupted, json object still be valid?
StaticJsonBuffer<200> jsonBuffer;
JsonObject& object = jsonBuffer.parseObject(mybuf);
Incoming uart:
mac:c2f154bb0af9,rssi:-55,volt:3.05,mag:1
Iterate and publish as
/ble/livingroom/c2f154bb0af9/rssi -55
/ble/livingroom/c2f154bb0af9/volt 3
/ble/livingroom/c2f154bb0af9/mag 1
1) count # fields in after MAC
2) concat "ble"/"MAC"/+iterate field
3) capture data to publish
if (object.success())
// Parsing success, valid json
//todo: it's too easy to forget mytopic size, not checking for size when string being assembled.
// add error checking and improve readability
int topic_char_index=0;
// mytopic[i] = '\0'; make sure null terminate mytopic
//construct the first part of the topic name, which is just /ble/mac
mytopic[0]='/'; topic_char_index++;
mytopic[1]='y'; topic_char_index++;
mytopic[2]='y'; topic_char_index++;
mytopic[3]='y'; topic_char_index++;
mytopic[4]='/'; topic_char_index++; //topic_char_index is 5;
//add gateway location name, /ble/LIVINGROOM
int mqtt_name_len = sizeof(mqtt_name); //returns num of chars + 1 for \0 character
#if MyDebug
Serial.print("topic_char_index before mqtt_name: ");
Serial.println(topic_char_index);
Serial.print("size of mqtt_name_len should be 16: ");
Serial.println(mqtt_name_len);
#endif
for (int i=0; i<(mqtt_name_len-1); i++)
#if MyDebug
Serial.println(mqtt_name[i]);
#endif
mytopic[topic_char_index] = mqtt_name[i];
topic_char_index++;
mytopic[topic_char_index] = '/'; topic_char_index++;
#if MyDebug
Serial.print("topic_char_index after mqtt_name: ");
#endif
//set string pointer to JSON Value containing the key "mac"
// so it's pointing to "mac":c2f154bb0af9
const char* mac_name = object["mac"];
#if MyDebug
Serial.println("mac name is");
Serial.println(mac_name);
#endif
int sizeofff = strlen(mac_name); //returns exactly number of characters in mac_name. Doesn't add 1 like sizeof
#if MyDebug
Serial.print("size of macname: ");
Serial.println(sizeofff);
#endif
// /ble/livingroom/c2f154bb0af9/
//fill mac address into topic name string
for (int i=0; i<sizeofff; i++)
mytopic[topic_char_index]= mac_name[i];
topic_char_index++;
topic_char_index++;
#if MyDebug
Serial.println("mytopic after mac address add");
Serial.println(mytopic);
#endif
iterate through sensor topics portions
/ble/livingroom/c2f154bb0af9/????
/ble/livingroom/c2f154bb0af9/sensor
//as we iterate through the keys in json, need a marker for char[] index
//up to the MAC address: "/ble/livingroom/c2f154bb0af9/" <---- here
int topic_char_index_marker = topic_char_index;
for (JsonObject::iterator i=object.begin(); i!=object.end(); ++i)
topic_char_index = topic_char_index_marker; //reset index to just after MAC location
/ble/livingroom/c2f154bb0af9/ <---- here
#if MyDebug
Serial.print("iterator::");
Serial.print(i->key);
Serial.print(",");
Serial.println(i->value.asString());
#endif
//client.publish(i->key,i->value.asString());
//copy string for key into the prepared topic string
const char* key_name = i->key; //funny, key_name has to be const to compile in ESP8266.
int keysize = strlen(key_name);
#if MyDebug
Serial.print("key size: ");
Serial.print(keysize);
Serial.print(", topic_char_index: ");
#endif
for (int j=0; j<keysize; j++)
mytopic[topic_char_index] = key_name[j]; topic_char_index++;
/* note that topic_char_index is sitting at position after rss"i"
* /ble/c2f154bb0af9/rssi <----- rssi, volt, etc...
mytopic[topic_char_index] = '\0'; //terminate string w/ null
#if MyDebug
Serial.print("topic_char_index of null char");
Serial.println("printing entire mytopic:");
Serial.print(mytopic);
#endif
//mqtt publish relies a null terminated string for topic names
client.publish(mytopic,i->value.asString());
}//end iterator
}//end if json parsed successful
else
client.publish(mqtt_name, "bad json format");
client.publish(mqtt_name, mybuf);
Serial.println("--->bad json:");
Serial.println(mybuf);
} //failed json parse
digitalWrite(LED, HIGH); //LED off
} //end routine localParseJson
// main loop
void loop() {
//client.loop();
if (!client.connected()) {
reconnect();
client.loop();
//buffer for reading serial, must be writable
if (Serial.available() > 0)
//received serial line of json
if (readline(Serial.read(), serialbuffer, serialBufSize) > 0)
digitalWrite(pinHandShake, HIGH);
#if MyDebug
Serial.print("You entered: >");
Serial.print(serialbuffer);
Serial.println("<");
#endif
localParseJson(serialbuffer); //call JSON iterator on this line from serial
digitalWrite(pinHandShake, LOW);
}//end seria.available
//every X seconds, publish heartbeat
if ((millis() - heartbeat_millis > 20000) || ((millis() - heartbeat_millis) < 0))
heartbeat_millis = millis();
heartbeat_cnt++;
conn_status = client.connected();
Serial.print("20 second heartbeat: ");
if (conn_status == 0)
Serial.print("mqtt dead, attempting to connect...");
client.disconnect();
delay(2000);
if (client.connect(mqtt_name))
Serial.println("failed to reconnect MQTT");
else
Serial.println("reconnected succesful");
else
Serial.println("mqtt alive");
client.publish(mqtt_name, "had to reconnect");
client.publish(mqtt_name,itoa(heartbeat_cnt, mqtt_buf, 10));
} //end heartbeat
} //end loop
