MQTT broker address: FQDN instead of IP
I have a MQTT broker on a VPS and every try to use the domain name was unsuccessful.
The only solution is to use the IP but this can change and then I need to flash again.
I found the same is happening for SNTP, the only solution being to use the router IP (fortunately the router has a NTP server).
Is any solution to use the domain and not IPs for MQTT broker address?
Thank you
This sounds like an issue with your network or router, not your ESP.
I have no issues using FQDN to connect to external NTP. Maybe try hard coding a DNS server to start and see if that makes a difference?
Thank you for answer.
Indeed for NTP could be the router. I setup an internal NTP server on router and this could be the reason. I will do some tests.
But this shouldn’t impact MQTT broker. Why when using FQDN for broker name here is no connection to the server?
I have other devices in the network connecting to the same MQTT broker using FQDN and are working fine. Of course these devices aren’t flashed with esphome.
