I am trying to create a button board that I can put on my desk to trigger the most used automations I have. I am using ezbutton (https://arduinogetstarted.com/library/button/example/arduino-multiple-button-all) library and my buttons are grounded (same set up as image in the link), no pullup to save space.
I am receiving messages when I listen to the topic, but when I press the button I get “Message 32698 received on homeassistant/switch/button1/state” That is a lot of messages in a few seconds. How do I stop it going from so wild?
I have put in a loop (if (now - lastMsg > 2000) ) to slow it down, but I dont know if this is correct.
I am also trying to get the state from HA in the event I want to move the button board it doesnt reset or change that state of the entities in HA.
My ESP8266 code is as follows:
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <Arduino_JSON.h>
#include <ezButton.h>
// constants won't change. They're used here to set pin numbers:
const int LED_PIN = 16; // the number of the LED pin
ezButton button1(12); // create ezButton object that attach to pin 6;
ezButton button2(13); // create ezButton object that attach to pin 7;
int SwitchedPin = 12;
ezButton button3(14); // create ezButton object that attach to pin 8;
// variables will change:
String strTopic;
String strPayload;
// Update these with values suitable for your network.
const char* ssid = "";//put your wifi ssid here
const char* password = "";//put your wifi password here.
const char* mqtt_server = "";
//const char* mqtt_server = "iot.eclipse.org";
const char *mqtt_user = "";
const char *mqtt_pass = "";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
void setup_wifi() {
delay(100);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
char dataBuf[length+1]; // define a char buffer to add 0 termination
memcpy(dataBuf, payload, length); // copy byte buffer to char buffer
dataBuf[sizeof(dataBuf)-1] = 0; // add 0 termination
String str_payload= String(dataBuf); // copy to string variable
Serial.println(topic);
if(strTopic == "homeassistant/switch1/mqttTest/cmd") {
Serial.println(str_payload);
if (str_payload == "ON") {
Serial.println("ON");
digitalWrite(SwitchedPin, HIGH);
client.publish("homeassistant/switch1/mqttTest/state", "ON");
} else {
Serial.println("OFF");
digitalWrite(SwitchedPin, LOW);
client.publish("homeassistant/switch1/mqttTest/state", "OFF");
void reconnect() {
// Loop until we're reconnected
while (!client.connected())
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("homeassistant-MQTTButtons","mqtt_user","mqtt_pass"))
Serial.println("connected");
//once connected to MQTT broker, subscribe command if any
client.subscribe("homeassistant");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
} //end reconnect()
void setup() {
Serial.begin(115200);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
// pinMode(BUTTON_PIN,INPUT);
button1.setDebounceTime(50); // set debounce time to 50 milliseconds
button2.setDebounceTime(50); // set debounce time to 50 milliseconds
button3.setDebounceTime(50); // set debounce time to 50 milliseconds
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
int status;
button1.loop(); // MUST call the loop() function first
button2.loop(); // MUST call the loop() function first
button3.loop(); // MUST call the loop() function first
//send message every 2 second
if (now - lastMsg > 2000) {
lastMsg = now;
if(button1.isPressed())
Serial.println("The button 1 is pressed");
client.publish("homeassistant/switch/button1/state", "triggered");
if(button1.isReleased())
Serial.println("The button 1 is released");
if(button2.isPressed())
Serial.println("The button 2 is pressed");
client.publish("homeassistant/switch/button2/state", "triggered");
if(button2.isReleased())
Serial.println("The button 2 is released");
if(button3.isPressed())
Serial.println("The button 3 is pressed");
client.publish("homeassistant/switch/button3/state", "triggered");
if(button3.isReleased())
Serial.println("The button 3 is released");
My configuration.yaml code :
switch:
- name: "MQTT Switch Test"
command_topic: "homeassistant/switch1/MqttTest/cmd"
state_topic: "homeassistant/switch1/MqttTest/state"
unique_id: "switch.mqtttest"
payload_off: "OFF"
payload_on: "ON"
optimistic: false
retain: true # or false if you want to wait for changes
Any pointers would be great.
