MQTT config.yaml changes!
Hope someone can help.
I know the YAML is depreciated at the next update, so I have been trying to work out the correct syntax, but I cant make it work.
I have moved lights and switches under the mqtt: section but I can get binary sensors to work.
I have pasted an example! Would someone mind pointing out the obvious to me.
binary_sensor:
  - platform: mqtt
    state_topic: "Sonoff/LoungePIR"
    availability_topic: "tele/sonoff_bridge/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    device_class: motion
Thanks in advance.
Rob
The example in the docs:
mqtt:
  binary_sensor:
    - name: "Window Contact Sensor"
      state_topic: "home-assistant/window/contact"
So, yours would change to:
mqtt:
  binary_sensor:
    - name: "Lounge PIR"
      qos: 1
      payload_on: "ON"
      payload_off: "OFF"
It’s the same basic change you made to the light and switch domains.
I’m sure I done that.
I’ll try again.
Thanks for your help
