I have two things, a 8266 relay and a nodemcu with a simple reed switch.
Ideally Id like to replicate the momentary push with the 8266 relay and use the reed switch to detect the door as open.
My question is I have been experimenting with the “cover” but I dont think this is going to work. When I want to trigger the door to open, I need to trigger an ON and OFF state for either the open or close of the door.
Anyone suggest how to integrate this with HASS?
Hi switched - I know this thread is a few months old, but I’m having a similar issue to what you originally had. I’ve been able to implement the momentary switch for my garage door, but I’d like to make it work with the “cover”. Were you ever able to get this working?
Cheers for getting back to me. Ah fair enough - the main reason I’m trying to get it working with the cover is because when using it with homebridge (control from Apple devices), the garage door cover will show up as an actual garage door, rather than a switch. Not a big deal, just being overly pedantic haha
