I’m maintaining a customized mqtt cover, and right now I see that the only ‘real’ difference with the official MQTT cover is the additional states that it includes: Closing and Opening.
Many of other Covers include these states, and I guess it should be just a matter of a few lines to add these states to the official MQTT Cover. Would it make sense to include these states?
Yes, for stopped I’m using UNKNOWN, but it has some limitations. Actually the code changes I did are quite simple, and the init for the covers already have that logic, so it’s only a matter of adding the proper overriding functions in the mqtt part.
Bump. I just tested the MQTT cover to see if it can speed up reading Shelly 2.5 in cover mode status and I was disappointed that when I configure the position topic it only reports two states, open or close. I have a script that sets position and relies on opening and closing detection so that it doesn’t interrupt if the blinds are currently moving.
So would it be possible to allow state topic together with position topic so that intermediate states are possible?
Yes, same problem for me.
Right now the shelly only send position when the movement is over.
So it would be really nice that the state_topic is not completly ignored and the opening/closing states are still processed, but closed/opended are generated by the actual position.
another way could be that closing / opening would be calculated es well:
opened : position > 0 -> allready done
closed : position = 0 -> allready done
closing: executed position command topic with a position bigger than actual position
opening: executed position command topic with a position smaller than actual position
That way after sending the command for open the state will be calculated with “opening” and after you got the new position it will change to open again…
@gitlemat how did you solve that with you customized mqtt cover? Do you have some code for it? Would be really nice because everything works now except the closing / opening states that the device (a shelly) reports) in its mqtt communication but you cannot use it because of the position…
