MQTT device tracker - ignore state change at night?
I’m having a spot of bother with monitor occasionally setting my itag to be ‘away’ at night - is there any way with the MQTT device tracker you can ignore changes at night?
I used to be able to do this when I used monitor in the {{ value_json.confidence }} mode, but since I set PREF_DEVICE_TRACKER_REPORT to TRUE to use the home not_home method (to simplify my config massively) I’ve lost that ability.
(By the way, I AM using monitor alongside iCloud3. Sometimes iCloud3 has issues of its own and when they coincide with monitor having issues…)
