I am writing some code for the MQTT discovery of a light-component.
I am trying to either implement it using default schema OR Json schema
(There is a different set of configuration variables depending on what schema you choose)
I started sending the discovery topic and payload for a default light-component to HA, and indeed an MQTT device is created. And I confirmed the “config” message that the MQTT broker received with the MQTT explorer.
But the light component I want to create has an RGB strip. So I add a key
{“rgb_stat_t” , “d_rgbstate”}
(which is directly from the other example for a light with RGB
But when I then create the light, the config message for the light component is empty. (And any other entity created after the light, but in the same Device… is not created)
The same happens when I add the “rgb_cmd_t” (or both, as is done in an example on the MQTT light documentation
I have already made sure the Json [doc] size is big enough (1024 bytes)
So now my questions are:
how do I check what Config message is received by HA (is it in a logfile somewhere?)
Is it possible that some combination of keys/variables create conflicts? (Do I need to remove some key when my light has rgb for example?)
I can’t seem to get a light discovered with rgb and white.
Have tried rgbw (with its state and command topics) instead of rgb(with its state and command topics)
And this works … I get a light component with a color wheel etc
Thanks a lot. I will have a look tomorrow.(its close to midnght here)
I am quite new to using MQTT.
In my understanding the line "stat_t": "stat/mqtt_test255C/d_switch",
is used to indicate to Home assistant , that it should expect to find the state of this entity at the broker under topic “stat/mqtt_test255C/d_switch”
I organized my state topics to all start with stat, because then all the state messages are under the same header in the MQTT explorer.
All my command topics (where Home Assistant should publish commands for my device) start with cmnd. They all are under a header cmnd in the MQTT explorer
It would for an mqtt sensor.
If you do not change the default and want to use home assistant discovery, you need to use homeassistant/an_Integration/entity etc.
HA needs a specific task path to monitor and it starts with ‘homeassistant’. It can’t watch everything. You can change that (but please don’t), but it can only watch one top level topic like that.
I think I found a mistake in the (arduino) code that creates the Config messages.
I use a char buffer to construct a the key-value pair for every single Config variables (and then copy that into the Json Document)
I think my buffer was too small
I used : {"rgbw_stat_t" , "d_rgb_state" }
My Code then adds unique identifiers to creates a buffer with: "rgbw_stat_t": "stat/mqtt_test255C/d_rgb_state"
where stat is for my organisation
mqtt_test is my Device and 255C is the last two digits of the Mac Address
The char buf[30] was only 30
Should work better now…
Thanks anyway for your fast response. Appreciate it.!
