Following the firmware update for my Doogle, and the Z2M and Mosquitto updates, MQTT is unable to display the sensors.
I have my sensor list in Z2M.
In the Z2M logs, I have “connected”.
When I listen via MQTT on zigbee2mqtt/#, I have sensor data.
Message 15 reçu sur zigbee2mqtt/Machine laver à 21:34 :
{"child_lock":"UNLOCK","countdown":0,"current":0.08,"energy":15.69,"indicator_mode":"off","linkquality":80,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"voltage":233}
QoS: 0 - Retain: false
Message 14 reçu sur zigbee2mqtt/bridge/logging à 21:34 :
{"level":"info","message":"z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Machine laver', payload '{\"child_lock\":\"UNLOCK\",\"countdown\":0,\"current\":0.08,\"energy\":15.69,\"indicator_mode\":\"off\",\"linkquality\":80,\"power\":0,\"power_outage_memory\":\"on\",\"state\":\"ON\",\"update\":{\"installed_version\":192,\"latest_version\":192,\"state\":\"idle\"},\"voltage\":233}'"}
Message 13 reçu sur zigbee2mqtt/0x6cfd22fffeb634d0 à 21:34 :
{"battery":24,"contact":false,"identify":null,"linkquality":156,"update":{"installed_version":16777241,"latest_version":16777241,"state":"idle"},"voltage":1200}
Message 12 reçu sur zigbee2mqtt/bridge/logging à 21:34 :
{"level":"info","message":"z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x6cfd22fffeb634d0', payload '{\"battery\":24,\"contact\":false,\"identify\":null,\"linkquality\":156,\"update\":{\"installed_version\":16777241,\"latest_version\":16777241,\"state\":\"idle\"},\"voltage\":1200}'"}
However, in Home Assistant no entities/sensors are displayed.
Any advice to add my device on HA ?
Configuration.yaml
homeassistant:
discovery_topic: homeassistant
status_topic: homeassistant/status
legacy_entity_attributes: false
legacy_triggers: false
enabled: true
advanced:
network_key:
- 33
- 21
- 64
- 58
- 46
- 141
- 177
- 155
- 207
- 20
- 115
- 136
- 34
- 115
- 84
- 135
pan_id: 27542
ext_pan_id:
- 18
- 69
- 150
- 107
- 164
- 196
- 230
- 195
mqtt:
server: mqtt://core-mosquitto:1883
user: ***
password: ***
base_topic: zigbee2mqtt
discovery: true
discovery_prefix: homeassistant
force_disable_retain: true
keepalive: 60
reject_unauthorized: true
version: 4
serial:
adapter: ember
port: /dev/ttyACM0
frontend:
enabled: true
port: 8099
device_options:
homeassistant:
discovery: true
devices:
'0xa4c13898423d37ec':
friendly_name: Salon
temperature_calibration: -0.3
'0xa4c138705dcb6095':
friendly_name: nom
'0xa4c138b219fe0a76':
friendly_name: Video projecteur
homeassistant:
discovery: true
'0xa4c1389ddcf74523':
friendly_name: Prise exterieur
'0xa4c13800be52d871':
friendly_name: Cellier
humidity_calibration: 0
'0xa4c138ce8a6a2268':
friendly_name: Extérieur
humidity_calibration: -1
'0xa4c13881d70db4b8':
friendly_name: Machine laver
'0xa4c138f09c15697a':
friendly_name: Cuisine
'0xa4c138d0c49d814d':
friendly_name: Salon presence
'0x0ceff6fffe4a900f':
friendly_name: Lampe salon
'0x94a081fffe5ec41e':
friendly_name: Prise ikea
'0x6cfd22fffeb634d0':
friendly_name: '0x6cfd22fffeb634d0'
groups: {}
version: 4
