Mqtt: domoticz voltcraft CO2 sensor in Home Assistant [SOLVED]
Hey you all,
I need some help with MQTT: I have a voltcraft USB airquality sensoer connected to a R-Pi running Domoticz and I have this Domoticz configured to send it through MQTT:
I have Mosquito installed on a Different R-Pi and it sees my domoticz sensor:
The following I wanted to add to my configuration.yaml:
mqtt:
  - name: "air_quality"
    state_topic: "homeassistant/18/state"
    unit_of_measurement: "ppm"
    icon: "mdi:hvac"
    value_template: "{{value_json.airquality}}"
I have it thus far that MQTT receives the mqtt message:
When reloading the YAML I get this as warning:
Configuratiewaarschuwingen
Invalid config for ‘mqtt’ at configuration.yaml, line 144: ‘name’ is an invalid option for ‘mqtt’, check: mqtt->0->name Invalid config for ‘mqtt’ at configuration.yaml, line 145: ‘state_topic’ is an invalid option for ‘mqtt’, check: mqtt->0->state_topic Invalid config for ‘mqtt’ at configuration.yaml, line 146: ‘unit_of_measurement’ is an invalid option for ‘mqtt’, check: mqtt->0->unit_of_measurement Invalid config for ‘mqtt’ at configuration.yaml, line 147: ‘icon’ is an invalid option for ‘mqtt’, check: mqtt->0->icon Invalid config for ‘mqtt’ at configuration.yaml, line 148: ‘value_template’ is an invalid option for ‘mqtt’, check: mqtt->0->value_template
What am I doing wrong here?
UPDATE: I changed the yaml to:
mqtt:
       icon: "mdi:hvac"
there are no errors anymore but I also am getting no readings, the entity remains unknown
can anyone helpo me with this?
value_template: "{{value_json.concentration}}"
Try this. airquality doesn’t appear in the json in your picture
Yes, it started working straigth away! :slightly_smiling_face:
Now I want to assign it a unique ID and a room, or can I better make a template sensor that takes it’s data from the original one?
