Hi, anyone knows about alternative of MQTT explorer for Raspbian or does anyone got the MQTT explorer working on Raspbian itselve please?
I don’t use MQTT explorer, but I don’t see a reason why you should not be able to install it on Raspbian. Does the MQTT explorer have a GUI or do you access it through a webservice?
Is there a reason you want it on the raspberry pi and not just use it on your desktop pc?
I got this when trying to instal:
pi@rpi:~ $ sudo snap install mqtt-explorer
error: snap "mqtt-explorer" is not available on stable for this architecture
(armhf) but exists on other architectures (amd64).
It has a GUI.
The reason is I am using the PI as my Desktop PC.
Ah I understand, Don’t know if there is a version for arm somewhere. Maybe MQTT.fx is a valid alternative?
currently following your same trail. did you ever find a work around for this issue?
not sure where you were but im knee deep in 433 transmissions that i need to sort out before i can add them into sensors…Figure thats about where you were as well
