My configuration file says:
mqtt: broker: 127.0.0.1
My MQTT configuration is:
{ "plain": true, "ssl": false, "anonymous": true, "logins": [], "customize": { "active": false, "folder": "mosquitto" }, "certfile": "fullchain.pem", "keyfile": "privkey.pem" }
Yet MQTT says it’s in the stopped state and my log says:
2017-11-23 11:45:56 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 191, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File “/usr/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 387, in async_setup
success = yield from hass.data[DATA_MQTT].async_connect()
File “/usr/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 497, in async_connect
self._mqttc.connect, self.broker, self.port, self.keepalive)
File “/usr/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/paho/mqtt/client.py”, line 768, in connect
return self.reconnect()
File “/usr/lib/python3.6/site-packages/paho/mqtt/client.py”, line 895, in reconnect
sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
File “/usr/lib/python3.6/socket.py”, line 722, in create_connection
raise err
File “/usr/lib/python3.6/socket.py”, line 713, in create_connection
sock.connect(sa)
Any suggestions? Everything worked fine is 0.57.2.
