I run Home Assistant since 1-2 years with MQTT and Zigbee2MQTT quite successfully with 40-50 Zigbee devices.
Last day I rebooted the VM containing HA and all my Zigbee devices got unavailable.
In Zigbee2MQTT, all devices are there as expected.
So I go to entities and here is the problem. All Zigbee/MQQT entities are there twice, for example:
sensor.capteur_as_battery
and
sensor.capteur_as_battery_2
And so on.
I could (maybe not successfully, delete every “old” entity, then rename the new one to old one). With ~50 Zigbee devices and 3-5x more entities, it’s a lot of work and will break some things.
The only thing I can think of is I moved the configurations files of Zigee2MQTT from \share\zigbee2mqtt to \config\zigbee2mqtt some weeks ago. Since then, I had updates, reboots successfully.
I restored the VM 1 day before to come back to a “clean” situation, but I can’t reboot as is as the problem will come back…
And strange thing happens with the config of Zigbee2MQTT; I changed the basetopic from zigbee2mqtt to homeassitant some days ago without any particular side effects.
Now, when I open the config o Zige2MQTT in the GUI, I get:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: tcp://192.1.1.6:3333
But if I open the file from the Samba share I get:
external_converters: []
devices:
- devices.yaml
groups:
- groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: homeassistant
server: mqtt://core-mosquitto:1883
user: addons
password: zzz
reject_unauthorized: true
include_device_information: true
keepalive: 60
version: 4
serial:
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
last_seen: ISO_8601
elapsed: true
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
So I’m not really sure how this is possible???
I’m on HA Core 2022.10.3.
Thanks,
Daniel
