Hi
I’m new to the forum but not new to HA…
The MQTT integration in my HA has stopped working for some reason
New devices are discovered by MQTT but do not show up on the integration page anymore (auto add new devices are turned on)
Here is log from MQTT addon
[12:48:29] INFO: Setup mosquitto configuration
[12:48:29] WARNING: SSL not enabled - No valid certs found!
[12:48:29] INFO: No local user available
[12:48:29] INFO: Initialize Hass.io Add-on services
[12:48:29] INFO: Initialize Home Assistant discovery
[12:48:29] INFO: Start Mosquitto daemon
1577706509: mosquitto version 1.6.3 starting
1577706509: Config loaded from /etc/mosquitto.conf.
1577706509: Loading plugin: /usr/share/mosquitto/auth-plug.so
1577706509: |-- *** auth-plug: startup
1577706509: ├── Username/password checking enabled.
1577706509: ├── TLS-PSK checking enabled.
1577706509: └── Extended authentication not enabled.
1577706509: Opening ipv4 listen socket on port 1883.
1577706509: Opening ipv6 listen socket on port 1883.
1577706509: Opening websockets listen socket on port 1884.
1577706509: Warning: Mosquitto should not be run as root/administrator.
1577706511: New connection from 172.30.32.1 on port 1883.
1577706512: Socket error on client <unknown>, disconnecting.
1577706512: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1577706513: New client connected from 172.30.32.1 as auto-A8A9F8BF-F002-AFDB-91B9-FA874B9CCD5C (p2, c1, k60, u'homeassistant').
1577706517: New connection from 192.168.1.185 on port 1883.
[INFO] found mqtt on Home Assistant
1577706518: New client connected from 192.168.1.185 as DVES_8C5E73 (p2, c1, k30, u'mqtt').
I can add my devices to TasmotaAdmin with out issues
Activate new devices is turned on in HA
It started today after I upgraded HA from a 190.x version to the latest 193
Any ideas?
