Hello all,
I’m developing a new integration for lights and need MQTT to receive ASYNC updates for LED brightness levels, especially when DALI scenes are activated.
Dev Environment: Set up development environment | Home Assistant Developer Docs
HA Core Dev Repo in VSCode devcontainer.
I verbatim copied this MQTT example code in separate folder under custom_component, and getting KeyError, MQTT may not be setup correctly.
However, when I copied my custom component folder code to a proper HaOS installation with MQTT Add-on installed and setup in Devices page, the error is gone.
Can someone guide me as to how to replicate this MQTT Add-on installation or equivalent in a HA Core Docker? Or I should setup a different Dev Environment to install Add-ons?
@patrick_jane made a similar comment in this thread: [SOLVED] MQTT not working in custom component
