Hi!
I’m trying to do my first project in Home Assistant, RGB lights using an esp8266.
Pretty much everything works except the card widget is kinda buggy.
When I turn the light on, the brightness slider is all the way to 0, no matter what the real value is.
because of that I cannot see the RGB picker until I change the brightness value.
Even worse, when the light is already on when I open the details view, I don’t even see the brightness slider. I need to turn the lamp off and on again to be able to see it.
my config looks like this:
mqtt:
light:
- name: "Nightstand Light 1"
state_topic: "bedroom/nightstand1/light/status"
command_topic: "bedroom/nightstand1/light/switch"
brightness_state_topic: "bedroom/nightstand1/brightness/status"
brightness_command_topic: "bedroom/nightstand1/brightness/set"
rgb_state_topic: "bedroom/nightstand1/rgb/status"
rgb_command_topic: "bedroom/nightstand1/rgb/set"
state_value_template: "{{ value_json.state }}"
brightness_value_template: "{{ value_json.brightness }}"
rgb_value_template: "{{ value_json.rgb | join(',') }}"
qos: 0
payload_on: "ON"
payload_off: "OFF"
optimistic: false
Even the sketch from the documentation has this issue.
Is there a way to fix this?
Thanks!!
