Mqtt light not visible in dash
Hope someone can steer me in the right direction. I’m trying to add a mqtt rgb strip using Tasmota firmware on a D1 mini. I added the mqtt under lights but the entry doesn’t show on the dashboard, I can publish the commands and the light responds correctly.
In configuration.yaml I have:
mqtt:
  broker: core-mosquitto
  username: hass
  password: hass
light: !include lights.yaml
In lights.yaml I have (also using limitless leds which work fine):
platform: limitlessled
bridges:
  - host: 192.168.1.47
    port: 9635
    groups:
    - number: 1
      type: rgbww
    - number: 2
      name: Water Wall Spot
      type: rgbww
    - number: 3
      name: Pavilion Rear Flood
      type: rgbww
    - number: 4
      name: Rear Yard Flood
      type: rgbww
Platform: mqtt
name: "Deck Middle Step"
command_topic: "cmnd/DeckMiddleStep/power"
state_topic: "stat/DeckMiddleStep/POWER"
rgb_state_topic: "stat/DeckMiddleStep/color"
rgb_command_topic: "cmnd/DeckMiddleStep/color"
brightness_state_topic: "stat/DeckMiddleStep/dimmer"
brightness_command_topic: "cmnd/DeckMiddleStep/dimmer"
retain: true
I’m thinking it must be some syntax error but I can’t figure it out and get no errors.
Found my problem, knew was stupid
- platform: limitlessled
  bridges:
      port: 9635
      groups:
      - number: 1
        type: rgbww
      - number: 2
        type: rgbww
      - number: 3
        type: rgbww
      - number: 4
        type: rgbww
- platform: mqtt
  payload_on: "ON"
  payload_off: "OFF"
  retain: true
Sure enough was indentations
