Hello Folks,
I have a problem with a lolin_s2_mini microcontroller which acts as a PIR Sensor and Publishes over MQTT.
It gets stuck once every 24h, and my lights do not turn on anymore.
Pressing reset and it works again.
The code is very straight forward:
#include <Arduino.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "config.h"
#define COOLDOWN_WAIT 5000 // Wait for 5 seconds
#define DURATION_PUBLISH_INTERVAL 1000 // Publish duration at most every 1 second
#define BUILTIN_LED 2 // Change this to the pin number of your board's built-in LED
WiFiClient espClient;
PubSubClient client(espClient);
unsigned long motionStartTime = 0;
unsigned long lastDurationPublishTime = 0;
bool motionDetected = false;
void setup_wifi() {
delay(10);
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void reconnect() {
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
if (client.connect("ESP8266Client", mqtt_username, mqtt_password)) {
Serial.println("connected");
// Flash the built-in LED 3 times after connecting to the MQTT broker
for (int i = 0; i < 3; i++) {
digitalWrite(BUILTIN_LED, LOW); // Turn on the LED
delay(200);
digitalWrite(BUILTIN_LED, HIGH); // Turn off the LED
delay(200);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
void setup() {
Serial.begin(115200);
pinMode(BUILTIN_LED, OUTPUT);
setup_wifi();
client.setServer(mqtt_server, mqtt_port);
pinMode(PIR_PIN, INPUT);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
int pirState = digitalRead(PIR_PIN);
if (pirState == HIGH && !motionDetected) {
motionDetected = true;
motionStartTime = millis();
client.publish("PIR/Gang/state", "true");
if (motionDetected && millis() - lastDurationPublishTime >= DURATION_PUBLISH_INTERVAL) {
int duration = (millis() - motionStartTime) / 1000;
char durationMsg[10];
sprintf(durationMsg, "%d", duration);
client.publish("PIR/Gang/duration", durationMsg);
lastDurationPublishTime = millis();
if (pirState == LOW && motionDetected) {
unsigned long cooldownStart = millis();
while (millis() - cooldownStart < COOLDOWN_WAIT) {
if (digitalRead(PIR_PIN) == HIGH) {
return;
client.publish("PIR/Gang/state", "false");
What is the issue here?
Many thanks in advance!
