MQTT Mosquitto broker error unknown connection
I am getting the error below in logs of MQTT. I assume this IP address is coming from an HA add-on. how can I determine what IP address this is tied to, meaning what HA add-on is attempting to connect to mqtt?
I am running the following:
  • Core 2024.7.1
  • Supervisor 2024.06.2
  • Operating System12.4
  • Frontend 20240705.0
2024-07-08 15:25:20: New connection from 172.30.32.2:44294 on port 1883.
2024-07-08 15:25:20: Client <unknown> closed its connection.
It is normal. It is the supervisor watchdog. If you want to test this you can temporarily disable the watchdog and see if the log messages stop:
Don’t leave this off. If the addon crashes for whatever reason the watchdog can restart it.
thanks so much. I was going crazy trying to figure out what service would continually be trying to connect.
