MQTT motion sensor
I’m trying to get my motion sensor to work in an automation but I’m failing to find out how the payloads its sending over mqtt shall be configured and used.
The sensor works fine and toggles between “motion detected” and “standby” when I trigger it.
I’ve tried to define it as a binary sensor but that doesn’t seem to work either.
Any tip would be greatly appreciated.
Sensor defined as the following works fine in HA - can view live status in a card:
  - platform: mqtt
    state_topic: "huset/sensornode1"
    value_template: '{{ value_json.motion }}'
#BinarySensorTest
  platform: mqtt
  name: "Källare (Rörelse)"
  qos: 0
  payload_on: "motion detected"
  payload_off: "standby"
Above doesn’t work…
And using the default sensor declaration in the following automation doesn’t work either.
#Automation 1#
  - alias: PIR 1  On
      - platform: mqtt
        payload: 'motion detected'
       service: light.turn_on
       entity_id: light.sn1_led
#Automation 2#
  - alias: PIR 1  Off
      - platform: mqtt
        payload: 'standby'
        service: light.turn_off
If this works, it means that the incoming MQTT message is encoded in JSON format, which means your binary sensor must decode this. At the moment it is expecting just text in the data. To get the binary_sensor to decode JSON, you need to add the value_template line to its definition.
