HI
i am getting this error from config
Cannot quick reload all YAML configurations because the configuration is not valid: Invalid config for [mqtt]: [name] is an invalid option for [mqtt]. Check: mqtt->mqtt->1->name. (See /config/configuration.yaml, line 25).
with this code
mqtt:
- climate:
modes:
- "off"
- "heat"
- "auto"
temperature_command_topic: "home/termostato/temperature_setpoint/set"
temperature_state_topic: "home/termostato/temperature_setpoint/state"
temperature_state_template: "{{ value_json|float / 10 }}"
current_temperature_topic: "home/termostato/current_temperature/state"
current_temperature_template: "{{ value_json|float / 10 }}"
mode_state_topic: "home/termostato/mode/state"
temperature_unit: c
max_temp: 30
min_temp: 15
temp_step: 0.5
retain: 1
- switch:
state_topic: "home/termostato/status/state"
command_topic: "home/termostato/status/set"
value_template: "{{ value_json }}"
payload_on: "1"
payload_off: "0"
qos: 0
retain: true
icon: mdi:power
- switch:
state_topic: "home/termostato/away/state"
command_topic: "home/termostato/away/set"
payload_on: "1"
payload_off: "0"
qos: 0
retain: true
icon: mdi:login
- sensor:
- sensor:
state_topic: "home/termostato/away_temperature/state"
- sensor:
state_topic: "home/termostato/current_humidity/state"
value_template: "{{ value_json|int }}"
device_class: humidity
Any ideas? Help?
