MQTT no longer talking to solar assistant
Hi all, hope life is good. Since recent updates my MQTT no longer talks to my solar assistant. All entities are showing off line and i have searched the problem and there are possibly similar problems being suffered by other. When i listen to MQTT there is nothing.
Research shows that maybe a bug has removed the P/W and user but i have no idea how to recover any of these.
Is this a known problem with a fix in motion or does anyone have any fixes?
My solar assistant is working fine through the app so info is getting through so not an issue with SA to servers.
Make sure solar assistant or whatever is creating the information in MQTT, is still doing that.
All home assistant does is display the configured topics. Nothing in the MQTT integration has changed. This is likely on the solar assistant side. They either stopped providing discovery, or they are writing to different topics than their discovery is providing, or they aren’t writing to the topics at all.
Hi
I suggest you use mqttexplorer to see if your solar assistant is publishing anything in mqtt.
