I’m creating a fish feeder with SG90 servo and NodeMCU
I used this sketch:
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Servo.h>
// Update these with values suitable for your network.
const char* ssid = "your_wifi_hotspot";
const char* password = "your_wifi_password";
const char* mqtt_server = "broker.mqttdashboard.com";
//const char* mqtt_server = "iot.eclipse.org";
Servo myservo; // create servo object to control a servo
WiFiClient espClient;
PubSubClient client(espClient);
void setup_wifi() {
delay(100);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length)
Serial.print("Command from MQTT broker is : [");
Serial.print(topic);
for(int i=0;i<length;i++)
if((int)payload[i]>194||(int)payload[i]<0)
break;
myservo.write((int)payload[i]); // tell servo to go to position in variable '(int)payload[i]'
}//end callback
void reconnect() {
// Loop until we're reconnected
while (!client.connected())
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
//if you MQTT broker has clientID,username and password
//please change following line to if (client.connect(clientId,userName,passWord))
if (client.connect(clientId.c_str()))
Serial.println("connected");
//once connected to MQTT broker, subscribe command if any
client.subscribe("OsoyooCommand");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 6 seconds before retrying
delay(6000);
} //end reconnect()
void setup() {
Serial.begin(115200);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
myservo.attach(D1); // attaches the servo on pin D1 to the servo object
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
The servo is working when I use MQTTBox in order to send a payload as “Decimal Array”, it is however is giving me a hard time when I send payload as JSON string.
If I send “Decimal Array” 1 it does turn Servo to position 1, however if I simply send 1 as a payload as a string it moves Servo to position 49. If I send payload as 2 it moves to position 50. If I send payload as 10 then position is 4948 looks like position of 1 and position of 0 at the same time.
My ultimate goal is to send those payloads via HomeAssistant which are sent as string or JSON, however I don’t find a correct solution at the moment. I would highly appreciate any help or solution.
