I’ve just recently purchased a conbee ii for my HomeAssistant (Running HA OS in a VM) I’m having an issue getting my first device discovered by the Mosquitto broker to be picked up in the integration.
The device is successfully publishing a payload from my home server
Mar 22 22:18:56 debian npm[9314]: Zigbee2MQTT:info 2022-03-22 22:18:56: MQTT publish: topic 'zigbee2mqtt/stikkontakt-3-lampe', payload '{"device_temperature":null,"energy":0,"linkquality":255,"power":null,"state":null,"update":{"state":"idle"},"update_available":false}'
Mar 22 22:19:02 debian npm[9314]: Zigbee2MQTT:info 2022-03-22 22:19:02: MQTT publish: topic 'zigbee2mqtt/stikkontakt-3-lampe', payload '{"device_temperature":null,"energy":0,"linkquality":255,"power":null,"state":null,"update":{"state":"idle"},"update_available":false}'
Mosquitto broker logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[22:14:24] INFO: Certificates found: SSL is available
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:14:25] INFO: Starting NGINX for authentication handling...
[22:14:25] INFO: Starting mosquitto MQTT broker...
1647983665: mosquitto version 1.6.12 starting
1647983665: |-- *** auth-plug: startup
[22:14:25] INFO: Successfully send discovery information to Home Assistant.
[22:14:25] INFO: Successfully send service information to the Supervisor.
1647983665: Config loaded from /etc/mosquitto/mosquitto.conf.
1647983665: Loading plugin: /usr/share/mosquitto/auth-plug.so
1647983665: ├── Username/password checking enabled.
1647983665: ├── TLS-PSK checking enabled.
1647983665: └── Extended authentication not enabled.
1647983665: Opening ipv4 listen socket on port 1883.
1647983665: Opening ipv6 listen socket on port 1883.
1647983665: Opening websockets listen socket on port 1884.
1647983665: Opening ipv4 listen socket on port 8883.
1647983665: Opening ipv6 listen socket on port 8883.
1647983665: Opening websockets listen socket on port 8884.
1647983665: Warning: Mosquitto should not be run as root/administrator.
1647983665: mosquitto version 1.6.12 running
1647983665: New connection from 127.0.0.1 on port 1883.
1647983665: Socket error on client <unknown>, disconnecting.
1647983665: New connection from 192.168.68.120 on port 1883.
1647983665: New client connected from 192.168.68.120 as mqttjs_4659c168 (p2, c1, k60).
Options (kept as default)
certfile: fullchain.pem
customize:
active: true
folder: mosquitto
keyfile: privkey.pem
logins:
- username: mqtt
password: ####
require_certificate: false
The device is not showing up in the entity list . What am I missing?
Any input is much appreciated.
