I have successfully set up an MQTT Notify service according to MQTT notify - Home Assistant and it works fine.
However, I have not found a way to get access to any data but the “message” which is stored in the value
variable. In particular, I need the “title” of the notification as well.
This is what I want:
mqtt:
notify:
- name: "LED Display"
unique_id: notify_led_display_1
command_topic: "cmnd/leddisplay/text"
command_template: "{{title}}:{{value}}"
qos: 0
retain: false
which obviously doesn’t work, since there is no title
variable defined.
How do I access the title of the notification?
