Perhaps it was regarded as so trivial a use of templates that no one documented it, but I’m a bit stuck.
I’m trying to create some remote keypads, run by ESP8266 modules that link through WiFi to MQTT. They need to be able to transmit state set requests when the buttons are pushed, and they need to be able to have the lights in the button mirror the state of the device.
It makes no sense to have every keypad get every event for the entire house, when it just needs to be subscribed to a few. So while mqtt_eventstream is great, it’s a firehose, and I need to be able to sip…
Specifically, what I’m looking for is to take the Events feed, and send it to MQTT, as appropriately formatted Topics, i.e.
homeassistant/switch.kitchen/state off
homeassistant/light.living_room_globe/state on
There are times it would be useful to simply dump the whole state, i.e.
homeassistant/thermostat.whole_house/state {"temperature":69.6, "max_temp":85.6, "mode":"heat", "current_operation":"idle", "fan":false, "away_mode":false, "current_temperature":70.5, "humidity":48, "target_temp_high":69.6, "target_humidity":35.0, "target_temp_low":69.6, "friendly_name":"Whole House", "unit_of_measurement":"°F", "min_temp":"54.8 @ 05:32:01 20-03-2016"}
But even then, it could be broken down as:
homeassistant/thermostat.whole_house/temperature/state 69.6
homeassistant/thermostat.whole_house/mode/state heat
homeassistant/thermostat.whole_house/current_operation/state idle
homeassistant/thermostat.whole_house/fan/state off
homeassistant/thermostat.whole_house/away_mode/state off
homeassistant/thermostat.whole_house/current_temperature/state 70.5
homeassistant/thermostat.whole_house/humidity/state 48
It would be great to be able to set from MQTT, i.e.
homeassistant/thermostat.whole_house/temperature/set 71.1
homeassistant/switch.kitchen/set toggle
homeassistant/light.living_room_globe/set {"brightness":128, "rgbcolor":[128,0,0], "state":"on", "transition":5}
I guess I could use /api/services/toggle or turn_on or turn_off…can I do a scene invocation through the API as well?
"POST /api/services/homeassistant/turn_off HTTP/1.1"
Thanks in advance for any help you can provide.
