MQTT publis payload_template
Hello!
I have an automation with this action:
    - service: mqtt.publish
        topic: "SERVER-oldip"
        payload_template: "{{states.sensor.wan_ip.state.split("=")[0]}}"
The error:
expected <block end>, but found '<scalar>'
The cool part is, sometimes it works and HA boots up fine, but other times it doesn’t.
I may add, it works in the “HA template debugger”
Edit: I’m still experimenting. Results are varying…
Edit 2: I may have found a working result_
to
'{{states.sensor.wan_ip.state.split("=")[0]}}'
