Similar to the mqtt.dump action, an mqtt.query action is necessary. This action would return the retrieved value as a variable to the calling script. Ideally, a parameter parse_json (that defaults to false) would take the MQTT value returned and parse it as JSON, returning an object to the calling script instead of a string.
Currently, users have to manually read the mqtt_dump.txt file in scripts, and manually parse the contents read from the file. This is racy and buggy.
That would require to carry a configured sensor just to get the data I need (once in a blue moon). I donāt need any functionality of the sensor, such as history or logbook.
With that, all of the limitations of the sensor machinery come. For example, home assistant has a limit on how long a value can be because of the database. And while you can have larger values, then the database gets enormous very quickly if the sense of changes.
That imposes specific requirements on the format of the data sent to MQTT, instead of allowing for arbitrary data to be queried and used in a script.
I have to touch YAML and restart HA or reload it for every change to the sensor.
Look at this:
Itās unnecessary complexity. I just want to issue a single query every once a month or so.
I think you want to create a new mqtt system. The current mqtt system is a push system: clients push messagesto the broker, the mqtt broker pushes received messages to subscribers. AFAIK there are no provisions to query a broker without subscribing. So a sensor makes sense, a query not so much.
Thatās simply not correct. MQTT dump works perfectly with retained messages as well as with waiting for a non-retained message to show up on the bus. All Iām asking is for the same feature in an mqtt.query action.
EDIT: I am not even asking for a feature where the action sends a message and then it waits for a response. This is just simply looking at whatever might already be on a topic that has been retained. Thatās really all Iām asking for.
No it isnāt. The mqtt integration listens to push messages from the broker, it doesnāt retrieve them or āask for themā. I suggest you read up on the mqtt protocol.
How does this work at the MQTT protocol levels so that broker knows it has to reply to your request? Where can I read about this please? Is it MQTT 3.x or 5.x?
Edit: There is no retrieve command in the MQTT protocol standard. To have what you want, the HA would need to keep track (and retain) raw messages from MQTT broker that would allow you to retrieve them locally. And this is where sensor can help you.
You want an action that temporarily subscribes to a topic and then either:
Immediately retrieves the topicās stored message (assuming itās retained).
If thereās no retained message then it waits, for the duration of a user-defined timeout period, for a message to be published to the topic.
The received message is reported in response_variable.
I think retrieving a stored message would be feasible but Iām not sure the development team would permit an action that has a variable-length timeout.
Actions typically have a brief, hard-coded timeout. Are you aware of any existing actions that have a built-in timeout feature?
I see what you are asking here, sounds not that hard and you have the models mentioned above as precedent and possible models of what to do. Contribute itā¦
In the mean time, do a tiny python script to do what you want and call that when you want to. I do one to shut off something in the back-end on occasion. Resets my rf433 battery alerts when I want to clear one after changing a battery.
When you want to run it itās an available action: āpython_script.battery_clearā.
Bingo! That describes perfectly what Iām requesting.
TBQF even if the action had a zero timeout and no way to configure it, that would already be useful for harvesting retained messages. But being able to wait arbitrary amounts of time for MQTT messages to arrive in scripts would be a gamechanger for heavy users of MQTT!
No, thatās the exact opposite of what I have requested. Your script is publishing stuff to MQTT. I want an action to read retained messages. I see no support in the python_scripts integration to read messages from MQTT.
Iām familiar with MQTT. I suggest you look up how the mqtt.dump action works, because (contrary to what you seem to be implying) that action already does half of what I requested here ā only instead of returning the data to the calling script, it dumps the data into a file called mqtt-dump.txt.
Ya, I use it to publish. You would need to use something else.
My point is you can easily roll your own function there using what is available in the broker, which is the same toolset HA would have to implement your suggestion.
Faced with the same requirement, I would create an MQTT Sensor that stores the received message in its attributes (16K of storage space and value isnāt limited to being a string) and exclude it from the Recorder integration (no history is maintained).
