Ok so it literally seems I take one step forward, and two back. I’ve had my first set up working, but after doing wrong setup on config.yaml it won’t boot back up. Anyhow I will read up again on how to properly rescue my setup via ssh and samba, instead of starting all over from scratch like I have been doing.
I can’t forward ports since I seem to be behind a double NAT. If I want to access my setup from outside my best bet will probably be to pay for the HA cloud monthly service. For the near future I don’t plan to access it from the outside so I didn’t set up lets encrypt and duckdns this time around. (At one point I had it as https:// but to get into it I would get a “site not secure” page first where I had to click to acknowledge it was not a “secure” connection)
So on my fresh install of hassio I added configurator, mosquito mqtt and samba.
this is on my config.yaml file
mqtt:
broker: 10.0.0.227
username: mqttuser
password: mqttUserPW
switch:
platform: mqtt
name: “Luz Cuarto Vale”
command_topic: “cmnd/CuartoVale/power”
state_topic: “stat/CuartoVale/POWER”
qos: 1
payload_on: “ON”
payload_off: “OFF”
retain: true
Then on the mosquito configuration I have
"logins": [
"username": "mqttuser",
"password": "mqttUserPW"
"anonymous": false,
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
on the tasmota switch, I did verify the CuartoVale topic on the mqtt setup. I am pretty sure it is connecting because the led’s stop blinking. I also selected the option to emulate wemo belkin.
My home assistant does recognize it as a belkin switch and works as expected, it also lists out the “Luz Cuarto Vale” on overview/states page but when I try to toggle the switch it doesn’t work.
What am I missing? Switches are connecting to the mqtt server, so it doesn’t seem to be a username/password problem. The info on the yaml file seems to be formatted correctly so not sure what else to look at other than restarting from scratch again.
