MQTT sensor incorrect type error
Hi.
I’ve just created an MQTT sensor in configuration.yaml by means:
# Example configuration.yaml entry
mqtt:
  - sensor:
      state_topic: "/test/topic"
It works but, in the configuration.yaml file I see this:
Any idea ?
Thanks in advance
I assume you’re using the ‘Studio Code Server’ addon?
This addon always shows errors where there are none.
The problem is, if you don’t know , are the errors correct or not.
Thats why i disabled it a long time ago.
If your code works and the ‘CHECK CONFIGURATION’ in Dev Tools does not complain, just ignore them.
Yes.
I’m using Studio Code Server.
Is there any better editor ?
The problem isn’t the editor, VSCode is really the only Software that i like from M$. :laughing:
It’s the Home Assistant Extension in it.
