knebb
1
I am trying to add a MQTT based sensor through configuration file as follows:
-sensor:
- state_topic: hzg/status
unique_id: hzgowtout.mqtt
unit_of_measurement: "°C"
device_class: "temperature"
force_update: true
value_template: '{{value_json.onewire.t_out[0]}}'
When using MQTT explorer the message in MQTT looks like this (sorry only screenshot):
When checking on the dashboard the sensor says “Unknown”.
I somehow guess it is because of the brackets (‘[’ and ‘]’), am I right?
How can I enter the sensor in the .yaml file so it gets recognized properly?
Thanks!
/KNEBB
123
(Taras)
2
Try this version of the template.
value_template: '{{ value_json.onewire["t_out[0]"] }}'
Your version leads the Jinja2 processor to think that t_out
is a list and it should get the zeroth item from the list.
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
3
Hello
It’s JSON, so you need to escape things with a .
Examples from one of my blueprints…
knebb
4
Tried these:
.["t_out[0]"]
.t_out\[0\]
None of them did work.
This seems to be working now:
value_template: '{{value_json.onewire["t_out[0]"] }}'
Mind the missing “.” before the first bracket and after “onewire”.
Thanks @123
/KNEBB
