Hi, yesterday was my first day with Home Assistant (works as a virtual machine) and I can’t handle displaying data from the temperature and humidity sensor (BME280). The sensor publishes the data to the Mosquitto server, which is installed on another computer on the LAN. My configuration is as follows:
mqtt:
broker: 192.168.0.204
port: 1883 #by default
client_id: home-assistant-1
keepalive: 60
username: mqttuser
password: <mypassword>
protocol: 3.1 #by default
- platform: mqtt
state_topic: "/room1/serwerownia/temp1"
name: "Temperatura - Serwerownia"
qos: 0
unique_id: ‘12644’
unit_of_measurement: "°C"
#value_template: '{{ value_json.temperature }}'
- platform: mqtt
state_topic: "/room1/serwerownia/hum1"
name: "Wilgotność - Serwerownia"
unique_id: ‘12645’
qos: 0
unit_of_measurement: "%"
#value_template: '{{ payload }}'
I found a possibility to call the mqtt.publish command in development tools, so I checked if HA is communicating with the MQTT broker, I published the package to /room1/server/temp1 and it reached other clients.
Could you help because I don’t really know what could be wrong?
