I am facing weird problems. Things started to fail out no reasons after I upgraded to 0.39.2. For example, my MQTT sensors suddenly stopped working.
When I subscribed to the same topic via other client (e.g. my android phone), I can see the payload. But in HA, the state of the MQTT sensor doesn’t change at all and remained “unknown”
Automation using MQTT still works fine. The payload of a topic can trigger the automation.
Service call using mqtt.publish works as well.
The MQTT sensors work again after I restart HA but the restart process took longer than usual.
Is this a bug in 0.39.2? Anyone else facing this problem?
i have the same problema.
with your 0.38.4 do you have acess HA from your android phone? i tested with 3 android… and show me LOADING DATA and not enter.
Just as a qualifier to this, I have been running 0.39.3 since Saturday with 4 MQTT PIR sensors going through mosquitto, and have not had a problem. Three sensors are through the MySensors MQTT gateway and one directly from an Esp8266.
I have restarted a couple of times because of configuration changes.
Are you using the internal broker or something else?
Maybe I should elaborate further on my MQTT sensors setup.
Firstly, I have 433Mhz sensors that transmit code when it is triggered. This code is then captured by a standalone gateway and then publish the code via MQTT.
In HA, I created an automation using MQTT trigger. For example…
I’m having similar problems with latest HASS version.
MQTT (mosquitto) sensor not reading on HASS, but reading fine when subscribed elsewhere. MQTT publish using HASS working fine. It used to work before. Is MQTT sensor broken in HASS version 0.40.1?
How do I check that. Where is the log on Linux and what should I look for? home assistant ?
Ps. Tried enabling logging in the mosquito config file. Didn’t work.
The log file is normally stored in /var/log/mosquitto/mosquitto.log, but it depends on how you configure it. You should get an entry stating your client-id connected.
I have the exact same issue. not all mqtt sensor stop working but I have 3 philips motion sensors which a poll via a node script and publish to mqtt. During the day they work fine. but mostly after the night the stop working. My guess so far is that because it’s dark and there no motion in the night there are no updates for a while and HA is not picking up changes the next morning. I checked the mqtt broker and I still see publishes from the script to mqtt, so it does not seem to be an issue with the broker.
I started HA with debugging on the mqtt component today to see if there is anything logged. So maybe I know more tomorrow, maybe not
I have the same issue! I have and MQTT alarm panel and after 5/6 hours of starting HA, he stops to work! If I use mosquitto clients I can see that the messages work as expected but HA doesn’t publishes or receives the messages. At the same time other components start to fail too (some command line switches and mysensors actuators).
I should see something like:
17-04-04 14:56:58 INFO (Thread-11) [homeassistant.components.mqtt] Received message on home/badkamer/temp: 18
17-04-04 14:56:58 INFO (Thread-11) [homeassistant.components.mqtt] Received message on home/badkamer/humidity: 35
17-04-04 14:56:58 INFO (Thread-11) [homeassistant.components.mqtt] Received message on home/badkamer/dht11/battery: 2989
I am also seeing a failure of an MQTT - ESP8288 sensor which was working until I did an upgrade. I am now running 0.41.0 on my ‘production’ version. I also have a kind of ‘development’ version running on a separate RPi which has a stripped down version of my Config. The same sensor seems is working fine on that version. They both use the same internal broker running on my ‘production’ RPi. I sometimes see this error when I click on the sensor icon:
